hi everyone,
my name is todd.
i am new to this site but not new to horology.
i have been collecting wristwatches for many years.
recently i have been getting into American pocket watches,
this is the watch i wore today, one of my favorites.
an absolutely pristine Gruen Curvex, not a scratch or scuff. keeping great time.
i like to buy good looking non runners and service them.
staffs, mainsprings, etc. etc.
not an expert, just a hobbyist.
todd
todd
Hi Todd, the above describes me to a T.
It's good to have you aboard, and I look forward to your future input. :)
I nearly forgot, what a cracking watch, I like it!
Hello Todd,
Beautiful watch, I think you will slot in nicely to this forum there are a lot of fellow tinkerers ( not sure if that's a word but you know what I mean) here.
Cheers,
Vic
todays' watch.
my Bulova Computron drivers N6.
absolutely pristine, not a scratch or scuff,
bought it as a non runner 10 years ago, pulled out a leaky battery, cleaned the contacts and it has run perfectly ever since.
i have a soft spot for well made early LED's.
Todd
Hello todd!
Damn I like that vintage led bulova! I also have a real softspot for these early led watches. I don't have
any "real" vintage one yet only a retro model from fossil, no pictures unfortunlately. I must get me one,
an omega 1601 TC2 time computer led from 1974 is ofcourse very high on the wish-list.. :lol:
thanks omega4sure, ,
it is very hard to find a good example of a Bulova Drivers watch.
they had so many high sides that brassing is a big problem.
and they were easy to scratch.
i ran into this perfect example by luck.
it must have sat in someones drawer for 30 years.
when i bought it it looked like it was made yesterday.
not a ding or scratch.
lucky me!
todd.
    • If the watch is new, just return it to the seller for a refund or replacement.
    • Keevo, Welcome to the group ! I'm thinking that you have some damage to the hour, and/ or minute wheel. Possibly just a bent, otherwise damaged, or missing tooth.   Your photo didn't post that I can see. I think you'll have to open it to start really finding the issue. Best, Randy
    • An industrial break cleaner , like Holts does a good job of rinsing off paraffin
    • In cap jewels on several watches I have serviced over the years. I've recently serviced a couple of Longines movements where the cap jewels were colourless. They are a real pain. Without colour they disappear when immersed in any liquid for cleaning 😲 Not necessarily. Cousins do a 10ml bottle for £26 which will last me for years. That's just half the price of a simple Bergeon silicone cushion, so not too expensive 🤣
    • I wanted to post an update as I have two movements running really well now, 230-250 amplitude , 0.5 and under beat error, and +/-8 seconds or so. I removed the hairspring assembly in order to start over and noticed that the terminal curve between the stud and regulator arm was distorted. The stud was lower than it should be. I massaged the curve to look pretty good and reinstalled it. I followed Alex's video advice, best I could with 10x magnification, and with the regulator arm set in the middle of the curve I adjusted the stud so the spring was centered. I then made sure I could move the regulator arm the entire terminal curve without upsetting the coils. I then put it back on the Timegrapher and began closing down the regulator pins until I saw a change in amplitude which means to me that the pins were now pinching the spring. I opened them slightly and it looks good except I have a 0 on dial down, +3 on dial up but -16 on crown down.  I'm a bit stuck on how to adjust out the positional error. I also noticed a drop in amplitude, 180-200 on crown down. In the other video link I posted at about minute 26 if I remember he adjusts out positional error by manipulating  the regulator pin gap. With crown down the hairspring falls away from the pin and the rate slows so he closes the pins a bit to keep them tighter in crown down position. That means the spring is tighter on dial up as well but then he moved the regulator arm to slow the movement.  There must be some Seiko experts here that have some methods for dialing out positional errors.
