After having experimented with some very cheap watches I thought it was time to attempt something a little nicer. Bought this silver pocket watch and took it apart. Noticed quite a few of the jewels were shattered so is likely to be beyond my skill set at the moment to restore anyway. Despite that, I decided, probably unwisely, to examine the mainspring and measure it up for a replacement so rendering it useless in the process.
The measurement I have taken are:
  • Height: 2.6mm
  • Thickness 0.2mm
  • Length: 520mm
  • ID of barrel: 16.5mm
  • Type TR
Then I find out there is no replacement to be found in the TR book which I accessed through the Cousins website. Am I not looking properly or have I made a big mistake in assuming a replacement could be found?
Many thanks.
  • Height: 2.6mm
  • Thickness 0.2mm
  • Length: 520mm
  • Type TR
Many thanks.
You can never be sure that the mainspring that is currently fitted is the right one. Check what size is needed for this caliber first, or measure the depth of the barrel and subtract 0.1mm to verify is 2.6mm is right.
Ah, that opens up quite a few more possibilities. The barrel depth is 3.4mm so it can be a considerably wider mainspring as long as I stay within 3.2mm to build in a little safety margin. You are right that the current mainspring almost certainly was not the correct one.
Exactly!
However, 3.4mm seems to be very deep, are you measuring correctly? What is the movement?
35 minutes ago, nickelsilver said:
Cousins lists a GR 6801, 2.60 x 0.20 x 540 16.5, that would work perfectly. It has a normal "tongue end", which will work fine with the hook in your barrel.
If the exact spring cannot be found, in what order of importance would you rate the different parameters? I would have thought that the type, height and ID of the barrel are absolute requirements. Thickness and length less so?
Strength, height, length.
I have measured with the depth gauge of a Mitutoyo caliper, resting the the base on two sides of the curvature, allowing the depth probe to reach the bottom, keeping it as parallel as I could manage.
Right, you are measuring to the top edge - do not forget that barrel lid takes some space also.
2.80 x .205 x 600 x 18 TR- End
GR7002TR
58 In Stock
£7.30
This is probably as good as it gets for TR end from what is available on Cousins site.
GR7002TR
Almost, but not quite. The 18 is too big as barrel ID is only 16.5mm (17mm on the reference sheet linked above so my measurement is likely to be 0.5mm off).
With TR springs being difficult to find, would a DBH not work better than a normal bridle? I am thinking that the hook at least has a hole to engage in?
Do not be concerned about 16.50mm Vs 17.00mm. All it means that you will not be able to push it in, but nothing stops you from using a mainspring winder, or your fingers to install the mainspring. 2.8 is way better choice than 2.6 for your deep barrel.
I have found GR7087 which is 2.90 x .19 x 520 x 16 is stock at Cousins which is probably as close as I will get. Many thanks Poljot and Nickelsilver for your kind advice!
The Generale Ressorts book specs the GR 7070 for this caliber, 2.90 x 0.175 x 500. Cousins has 87 in stock at a whopping 7.30 GBP. Dang, I get my springs directly from GR and they are always 25 CHF and up!
  • 3 months later...
The Otto Frei web site carries mainsprings as well, categorized by end-type, strength/thickness, height, and length.  If you should ever have trouble getting the spring you need at Cousins (which I think would be rare) then Otto Frei is a handy back-up.
Looks like it was made in St. Imier, excellent watch. I wouldn’t worry to much about the jewels I bet you it’ll keep good time anyway. You can change them at a later date ?
  • Similar Content
    • Why now Mark ?  And which contact has brought you here ? People have been trying for bloody months to get hold of you for reassurance. Shite way to run a forum tbh. Seven months since you last visited. I think we all need to have a long discussion with you about what happens if anything happens to you. Please look forward to lots of questions.  Thanks for the link John, it will be interesting to find out how much it costs when they email me back.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
