Hello and thank you to all who are reading this! Ive been servicing my own watches for about a year now and have worked my way up to servicing my seamster. I assembled the movement last night, but decided to wait on casing it up until this morning. I threw it up on the timegrapher to regulate it and ended up with pretty good results with minimal positional error. This morning, before casing it up, I checked it on the grapher again and the reading is off. Though the machine says the rate and amplitude are the same as last night, the line drawn has now become erratic and beat the beat error is now fluctuating between about .1 and .8 ms. Im guessing another cleaning and oiling is due, but I wanted to hear if any of you guys had any input. This is what its reading IMG_5690.HEIC
I've serviced several Omega 102x movements, and I've noticed that they're rather quiet, so my timegrapher will sometimes struggle to get a clean reading.  I've made some measurements, and the signal from the 1020 will be 100 times smaller than an old pocket watch.  I'm not familiar with your timegrapher, but maybe adjust the gain settings?
If you can see that the balance has good amplitude, and you're confident in your cleaning/oiling, I would wear it and see what kind of performance you get.
 I have a link to a website below that you can use to convert your image files to JPEG which the discussion group can look at versus the file you have which the discussion group Process and most people probably can't look at it.
out of curiosity which timing machine are you using?
it would be nice if you'd wind it up again give us a photographs in preferably two positions. Either dial up or dial down and one of the crown positions like crown down fully wound up. but as a reminder fully wound up means you wind it all the way up but let it run about 30 minutes and then put it on the machine.
out of curiosity how did you clean this watch? Then did you remove or replace the mainspring? Tell us about your lubrication techniques
then background history what was the watch doing before you serviced it?
https://heictojpg.com/
I forgot for up above it would also be nice to have a picture of you holding the watch in the movement holder so we can see if there was an issue with how the machines picking up the watch plus whether you've ever had this happen before?
From my experience for some movements the correct setting of the gain makes a great difference. Try increasing or lowering it and see if you can get a more stable reading. Also try putting it on the timegrapher without a case if you haven't already. Sometimes it can be possible that the reading gets disrupted by other devices nearby, also check on that ?
As @handwound says, try it without the case. Being in the case can cause extra noise/errors on the signal, especially if it's a quiet movement.
I'm working on a Seiko 4006 and have it on the timegrapher this morning. The second picture is where I've loosened the screw on the holder slightly - similar to being in an open case and not held securely - you can see extra noise. That's why  I always put the movement directly in the timegrapher.
Edited by mikepilk
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
