When wearing an automatic watch, my wrist's natural warmth transfers to my watch.  But I live in a snowy clime and my "workshop" is unheated when not occupied.  Any sense of the effect of low temps on watch function?  If it gets down to, say, 3 F/-16 C at night, do I need to warm things up before I can trust my Timegrapher?
The balance wheel should exibit temperature isochronism, a lot of development over the last hundred+ years to prevent alteration in frequency from temperature.  If you're wearing your watch outside your parka (so you can see it) in the arctic, you'll want to get your watch serviced with an oil that's designed for low temperature, it has a different viscosity so it has correct performance at the target temperature range.
Cold weather would in theory thicken regular watch oils and slow the watch, you'd have to measure to determine how much (outside the regular variability of your watch)
Re-reading your question, there's a second part: what is the temperature isochronism of your timegrapher? I don't really know the time regulation circuit, assuming it's similar to a quartz watch using a quartz crystal, (might be mems?) the crystal will change in frequency depending on temperature (although much less than a mechanical watch). This should be thermally compensated (ideally), but there must be some remaining temperature-related variability, and that should be stated in the (quality?) manual.
http://www.leapsecond.com/hpan/an200-2.pdf
Good writeup on various factors effecting quartz frequency stability. It depends on a bunch of things, including temperature and age and design of the crystal, uncompensated temp variability might be something like  5ppm/degree Celsius, so over 36 degrees (room temp 20c to overnight temp of -16c) that's 180ppm, or 0.018%, or 15 seconds per day if my math is correct here (86400*.00018). That's pretty large, so you would expect it to be thermally compensated, but who knows? I think quartz crystal are designed for stability in  a temp range and then they drop off stability. I would warm up your timegrapher to within operating temperature specs before expecting expecting accurate readings.
My only experience with such things is with mechanical cameras. I have a few older Leica fully mechanical cameras and they tend to have shutter release problems below about 20degF so they need to be kept inside you parka and taken out only for quick use.
For the famous Leica ///c series during WWII they made a special version with ball bearings in the film transport and I believe used special lubricants especially for winter use. You know, so the Germans could take photos of their glorious victories on the eastern front.
*1 On Leicas.   On the plus side, the older M's had no battery to die in the cold. ?  I have a couple of these. . . an M2 with a modern Rapidwinder on it is a particular favorite.  Then again, it is never surprising that folks who appreciate mechanical watches also like mid-century tech that is as refined as a Leica.  The M3 with a 50mm lens and its 1:1 finder can be used with the shooter's right eye to give you a both-eyes-open head's up display on the world.  Pretty darn cool.  Also true of the Nikon S2.
    • This is the old/first(?) way for making a mainspring for an automatic. "Evolution-wise" it is an logical first step forward from a standard spring. Usually these are indeed replaced with a new spring with an integrated/fixed bridle. Lubrication as you would do with any automatic.
    • I'm working on a Schild AS 1250 (a 'bumper' automatic) and it's the first time I've seen a mainspring like this. It has what looks like a regular manual-wind mainspring with a 'hook' at its outer extremity. On a manual-wind watch that 'hook' would engage with a 'hook' in the barrel wall to prevent it from rotating. However, the AS 1250's mainspring does not engage directly with the barrel but rather with a 'sliding bridle' that sits between the mainspring and the barrel wall, and evidently facilitates the slip necessary in an automatic. I'm not sure what advantage this two-piece configuration provides, but it highlights a gap (one of many) in my horological knowledge. I'm not sure if 'hook' is the correct term as used above, but please see photo below to see what I mean. Therefore, two questions please. 1. What is the proper way to lubricate a barrel from an automatic watch with a sliding bridle? My guess is the same as any automatic ms/barrel (e.g, a few dabs of braking grease on the interior barrel wall). What do the experts say? 2. I purchased a Generale Ressorts GR3472X mainspring, made for the AS 1250. It looks like the bridle is included and I don't need to salvage and re-use the old one. Is this a safe assumption? Thanks for the advice. If you have any other wisdom you'd like to share about separate sliding mainspring bridles, I would be very interested. Cheers!
    • Thank you Hector. You too matey 😊
    • Bless you, Mark. May you live long and prosper!
    • That’s a nice idea, But i’m committed to providing this site as a gift to the watch repair community as my thank you for my incredible life i’ve had in this business. Ive done well and unless my financial circumstances change then i’m more than happy to foot the bill. If circumstances do change then be assured that I will make an appeal. For now, I’m comfortable with the way things are and I am extremely delighted to remove Google Ads from this site and to stop Patreon, it feels like a major step forward 🙂 Sorry, I missed your reply, I got blinded by another poster in this thread. Yes - I can confirm that I have always seen WRT as a not-for-profit website, and therefore - not a business as such. I’m lucky and have done well in my life due to a decision made in my teens to start a watch repairing apprenticeship which has sustained myself and my family for many years now. Consider this my small way of paying it forward. Ive been committed to keeping the site alive on a technical and financial level for over 10 years now and I have zero plans to change that. Thank you for your kind words by the way. And as for your wish - nobody can control what happens in life, if something happens to me I have things in place with my family but I’m just not comfortable talking about my personal business - I wish a certain person would respect that, but i’ve calmed down now - i’m only human 😄
