I had been using a study desk as my work bench, due to the height it's giving me pain in the neck and making it difficult to concentrate and work for longer that few minutes at a time. I need a proper desk to work on the watches. I am contemplating on getting a new workbench made, however it expensive and there are no ready made unit available, since it's not many people looking for it over here where I am at.
Few days ago, stumble upon an ad in the local used market on the internet for an old Jewellers desk and it's going for RM 100.00 that about USD 30.00. Here it is below, it's 36 inches tall and 31 inches wide with about 20 inches depth, just nice for me and it doesn't cost a bomb.
It's heavily used by the old Chinese gentleman that quit jewelry making and just decide to get rid of it. It's made of hard wood and must be around 30 years old, about that.
I will need to clean it and probably give it a much needed rub down and stain it back to seal the wood.
Very heavy and made to last.
All looks ok, except the skirting on the right. The wood crack and I will need to remove all the skirting and redo them.
It has three drawers, the top most is the widest.  I can use it as a catchment and the keys are still there :)
Okay, I am excited today and will need to do lots of work on it. Slowly I'm getting my work area done.. :)
Affnan
Thats a good solid bench and will clean up great. And for about £18 thats a bargain. Good find!
I would imagine they had some kind of pendant drill on the side where the damage is, but it's an easy fix.
Did a quick preliminary assessment and remove the skirting, right side skirting split in two other than that everything looks good. Will glue the two piece and make use of wood filler to make it good. I think the old wood can be reuse, no replacement required.
After removing the skirting, wow..  the worktop... it's almost 2 inch thick of solid wood !! Maybe because it's a jewellers desk it was made to be thick for hammering and what else the jeweller need to do on it.
Will continue tomorrow with some sanding, fixing the broken skirting and cleaning up the rest.
Affnan
Nice and compact and quality construction. I could use something like that, given my limited space. Good score!
Work bench nice and cleaned and replaced the top lock, made a mistake of getting the plastic wood. It is same color as the sides but the work top is darker.
Applied Mahogany wood stain and sealer, the worktop being a jeweller desk it has sign of burnt on the front part and some surface dent due to that. So the plastic wood used as filler... but wrong color :( well, the top may need to be skimmed... but it is not that critical.
I will put a table mat on top for better work surface and a good work light next. So far I can only find the round but not the rectangular work lamp.
Affnan
Completed with worktop mat and Ikea lamp, will get a better rectangular watchmaker lamp if I can get it here at reasonable price.
Now I can do more hours on it.
Affnan
Edited by AffyNoX
As far as I can see you got yourself quite nice piece of antique furniture. The drawers sides are dovetail joints? Are draws bottoms solid wood?  If so it is not just an average furniture making job. The whole desk looks like it is being built by an experienced tradesman.
Co you stick a close up of the different woods there? Maybe we can identify them so you would have complete description of this little beauty.
Edited by zenon
    • If the watch is new, just return it to the seller for a refund or replacement.
    • Keevo, Welcome to the group ! I'm thinking that you have some damage to the hour, and/ or minute wheel. Possibly just a bent, otherwise damaged, or missing tooth.   Your photo didn't post that I can see. I think you'll have to open it to start really finding the issue. Best, Randy
    • An industrial break cleaner , like Holts does a good job of rinsing off paraffin
    • In cap jewels on several watches I have serviced over the years. I've recently serviced a couple of Longines movements where the cap jewels were colourless. They are a real pain. Without colour they disappear when immersed in any liquid for cleaning 😲 Not necessarily. Cousins do a 10ml bottle for £26 which will last me for years. That's just half the price of a simple Bergeon silicone cushion, so not too expensive 🤣
    • I wanted to post an update as I have two movements running really well now, 230-250 amplitude , 0.5 and under beat error, and +/-8 seconds or so. I removed the hairspring assembly in order to start over and noticed that the terminal curve between the stud and regulator arm was distorted. The stud was lower than it should be. I massaged the curve to look pretty good and reinstalled it. I followed Alex's video advice, best I could with 10x magnification, and with the regulator arm set in the middle of the curve I adjusted the stud so the spring was centered. I then made sure I could move the regulator arm the entire terminal curve without upsetting the coils. I then put it back on the Timegrapher and began closing down the regulator pins until I saw a change in amplitude which means to me that the pins were now pinching the spring. I opened them slightly and it looks good except I have a 0 on dial down, +3 on dial up but -16 on crown down.  I'm a bit stuck on how to adjust out the positional error. I also noticed a drop in amplitude, 180-200 on crown down. In the other video link I posted at about minute 26 if I remember he adjusts out positional error by manipulating  the regulator pin gap. With crown down the hairspring falls away from the pin and the rate slows so he closes the pins a bit to keep them tighter in crown down position. That means the spring is tighter on dial up as well but then he moved the regulator arm to slow the movement.  There must be some Seiko experts here that have some methods for dialing out positional errors.
