Hi All,
I'm Matt from the UK, a father of four, and have always spent a lot of down time (toilet and waiting in queues) watching various horological videos on YouTube. Some of my favourites are ClickSpring, Master Watchmaker, Nekkid Watchmaker, Reuben Schoots, and RWSmithWatches. Scattered amongst all of these are a lot of hand & machine tool restoration and machining. It is clear where my passions lay.
I'm an electrician but haven't worked in that field for more than a decade. I'm now tied to a desk as a programmer (which I love), but I miss working with my hands. The children are growing up rapidly and are now becoming quite independent, one in particular is close to flying the nest. This means I'm now have a bit more free time and why my fingers were getting itchy!
My exact path on this hobby is not yet clear, but I do have it in my mind that one day I'd like to construct my own timepiece from stock. That would be many years off, so as it currently stands I'm purchasing old movements and practising taking them apart and putting them back together. In addition, I'm making my own simple tools. My next project is several pairs of hand levers in silver steel and brass.
It is great to find this forum and community.
Cheers,
Matt.
Welcome Matt enjoy the forum. Horology is one of those hobbies / skills that has a never ending learning curve and it can become very addictive.  However there are rewards when yo get a vintage non running watch back up and running. Enjoy the  forum.
Thank you all for the warm welcome. I will be completing my first strip downs and assemblies this weekend. I'll be doing it on a cheap Ebay bought movements. It won't be a service exercise, more an orientation and practice session.
I've repaired a few iPhones for my kids in the past. Battery, screen, and camera replacement mostly and what is interesting is how similar the core tools are and the working practices. Equally, I've built my fair share of models (one of my kids is into Warcraft 40k), Meccano, and electronic circuit boards.
So whilst this might be my first rodeo, I feel like I have some of the riding skills already in place.
Any advice beyond a clean, organised, working environment and recording each step of the process?
  • Similar Content
    • Did you just swear at me matey?? I’m sorry, I’m not divulging personal information but there’s always personal reasons. There’s not much more than I can do other than plod along as best I can. However, my health is good now and I’m regularly getting plenty of exercise to keep it that way 👍 You know what. The ads don’t even cover a small percentage of what it costs to serve this site. I find most of it personally. If there are complaints then so be it. I do my best.  in fact - I have zero issues turning them off. Would that make the complainers happy?
    • Same question that was asked last time Hakan, and emphasis was placed on it. It was ignored. The thread should still be there, if not I have a copy of his reply.
    • This is probably the single most important point. One of my best friends, 48 years old at the time, suffered a massive stroke about 15 years ago. He barely survived, but his life was never the same after that. If you had asked me back then to guess which of my friends might have a stroke and nearly die, he would have been the very last one I'd have picked. He was perfectly healthy, played tennis three times a week, ran a successful business, was full of life, and had a wonderful wife and well-behaved teenage kids. The harsh truth is, we never know when it’s "game over." @Mark, I truly wish you a long, happy, and successful life. But have you given any thought to some kind of backup plan for WRT in case the worst should happen? Is there anyone who could keep the site going? If you can reassure us in some way, it would mean more than a lot to us!
    • Update: The demagnetization only helped temporarily, maybe it pulled the wheels into a position where they liked each other. I have to adjust the sub second hand as it is a bit angled upwards and catching the minute hand stopping the whole movement but before this happened there were some wild deviations. HWGIKE#58 Alarm clock, cooked in hot cleaning fluid and oiled gently. This is a movement so I count it. 🙂 A while ago it tried to fly away one day, it was on my windows sill, we had strong wind the curtain flew like a flag and doing so encouraged my clock to do the same...  went out and ended up on the roof above the entrance door, its door in pieces but the clock itself suffered no damage otherwise. The original glass was already broken when I received it I still have the bottom part in two pieces. The new "glass" is acrylic. It also had a paper in the back in the case inside but it disintegrated, I still have a little bit of  piece of that too.     HWGIKE#59 Durowe 870 / Times M84 This particular instance is a D870, when I saw its worn out contact pin I thought that it must be a design flaw, and here we go: https://17jewels.info/movements/d/durowe/durowe-870/ An incredible movement again where the balance wheel drives the train and has two magnets one for the balance wheel/coil and one for the pallet. The magnet for the pallet is basically the "draw" one direction. The coil is about 1.8kOhm and one end is in contact with the main plate and the other end is soldered to a contact pin which is insulated by the means of putting it into a jewel and this contact pin is rubbing against a wire getting the energy/impulse as it is passing. Behind the contact pin there is an "impulse jewel" not sure why is it there... the wire seems to hit the impulse jewel first then the contact pin but maybe it is there only for insulation purposes? I was almost certain that the screw holding down the battery - (minus) clamp had no insulation washer.. i only noticed the green stuff around it coming from battery leakage... anyway the + and - had a shortcut which took me a while to realize.. had to fabricate one insulating washer on my own. The jewel settings were dirty but not it is all cleaned and oiled. The contact pin might work for a while but I am sure it has a short life. It is a front loader the whole thing is held together by the case so it is not possible to regulate it without putting it all together and taking the movement out of the case again, very inconvenient. A wonderful movement but not made for eternity only for the consumer market.
