I have broken a lyre spring on an RL1235.21 and have found the below on the incabloc website. What part number would be for the main plate lyre spring 770.03 or 775.03 as im not sure what is classed as above or below?
Part two - I do not have a jeweling tool but do have a staking set. I believe I will need to push out the setting. My idea was to use a staking set to push it out slightly to put in the spring and then set it back in again?
Would anyone have any better ideas on how to go about this?
first time I have ever broken one. Pretty gutted I did it but it is what it is.
Pictures are always nice  just so we can confirm what's going on..
Usually below is the main plate above is the  backside of the watch. Usually on the backside of the watch the parts are physically bigger because they look pretty.  So the bigger physical size spring will be visible  the smaller will be on the Dial side
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
    • A local machinery auction this week is liquidating some watchmaker's equipment. Actually a truly absurd amount of it, from a machine collector's estate, making me wish I had waited a couple of months to buy my lathe because there are so many options at low prices. Anyway - there are a handful of faceplates on 8mm collet mounts up for sale and I think I can probably get one. Having never had one in hand, they seem kind of large as described though - all are listed at either 4in (101mm) or 3 11/16in (93.7mm) diameter. As I understand it, WW lathes are 50mm from spindle center to bed so it seems like the 4 inch faceplates would not have enough clearance. Could I expect the 3 11/16in to fit with a WW headstock and bed? What is a typical diameter for a faceplate? Also possible the description of "4 inches" is only a rough estimate by the auction house and not actually accurate. Example the 3 11/16": I may have answered part of this - a lot of the listings on ebay from typical American lathe tool makers are specify about 3.75 inch diameters. Still I don't see any that specify 4 inches, but I am still guessing that is an overestimate by the auction broker.
    • Buying a specific jewel for a specific movement is difficult if not impossible in most cases. cousinsuk/jewels
