They're very useful for all kinds of things. I have a bunch of these scattered around the workshop. There are two main types- ones with flat plain tables and ones with the die plate like yours; and two main makers, both made both types, Tavannes and Prazision Falke. The Tavannes are usually 0-25mm, Falke 0-15mm.
They can be used for finding lengths along an arbor, using the die plate or a bench block if you have a plain table. Taking heights/depths off a plate or bridge. Nice for measuring inside of barrels (from barrel bottom to lid ledge for example). Pretty much any time it would be tricky to take a measurement with a regular micrometer these can help.
9 minutes ago, Klassiker said:
When does the tilt function come in handy?
It's just so you can see things more easily; with a horizontal bench mic or handheld mic it's not an issue,  but with these you find yourself bending over a lot to get at eye level with the spindle. I usually use it on my watch bench so rarely use the tilt
Big big thanks. I need to find the manual as well
Ok, I bit the bullet and picked this up tonight for $200 bucks Canadian. It is in absolute mint condition as I lay here on the couch wondering what I will use this for the most:) any detailed suggestions will really be appreciated.
It is beautiful.  Some things you just have to admire.  I do.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
