Hi all,
I have been breaking my head over how to recoil an omega 1310 motor, replacements are hard to find (or expensive) and I would like to glory of just fixing it myself. I have been doing some calculations about the copper diameter and length, but the results seem strange. I was hoping someone else tryd the same thing before and could help me out.
First of all, the tech sheet says the coil should be 2k2ohm (http://primrosesupplies.com/Swiss Tech Guides/Omega tech Guides/1310.pdf). Given this and the measured dimensions of the broken coil it should be easy to determine the copper diameter, right? however, doing the calculations I come down at 33micron. this seems quite strange as: a) its an unusual value for emamelled copper, 2) under a microscope the copper of the old coil looks just as thick as a 10micron wire I have laying around. So may questions are: does any body know the real diameter I should use? Did I overlook something? Is my math off? The calculations are added below
thanks in advance!best regards, Bert
The math:
# wire radius
r_d = 0.02/2
# coil inner and outer radius
r_inner = 1/2
r_outer = 4/2
# coil lenght
l_c = 10
# cutt through area of wire
A_d = (r_d**2)*3.14
# cutt through area of coil
A_c = (r_outer**2-r_inner**2)*3.14
# volume of coil
V_c = A_c*l_c
# volume of wire inside this coil
f = 0.9069 # maximum circle fill rate (https://en.wikipedia.org/wiki/Circle_packing)
f = 0.8    # a common sense adjustment
V_d = V_c*f
# V_d = 75
# so, the length of the wire
L_d = V_d/A_d
L_dm = L_d / 1000
# and its resistance
R_copper = 1.724e-5 # ohm*mm^2/mm at 20C
R = R_copper * L_d / A_d
# R = 16k5 ohm
# what the optimal diameter would be to achive 2k2
d_opt = sqrt(sqrt(R_copper*V_d/2200)/pi)*2
# --> d_opt = 0.033 mm
# sanity check
# volume of copper by weights measurement of old coil
V_copper = 1000*0.68/8.93
# V_copper = 76 ~ whats been calculated
way to many figures there for me I'm afraid, my mind is a boggle with DLC calculations at the moment, but, is there not another coil from lets say a miyota movement that would fit? I have no idea to be honest just spit balling an idea out there, you known just incase.
Hi transporter,
Thank you for your reply. I did look for possible replacement, the only one know to fit is the tissue 2100, unfortunately these are rare as wel. I assume others might serve as a donor as well, but would't like to go buying movement after movement for test by trail. But maybe this extends my questions with: are there any other donor movements known?
Regards, bert
1 hour ago, brtvandenbroeck said:
Hi all,
The math:
# wire radius
r_d = 0.02/2
r_inner = 1/2
r_outer = 4/2
# coil lenght
l_c = 10
A_d = (r_d**2)*3.14
# volume of coil
V_c = A_c*l_c
V_d = V_c*f
# V_d = 75
L_d = V_d/A_d
L_dm = L_d / 1000
# R = 16k5 ohm
# sanity check
I analyzed this a little differently than you.  Essentially, I put my analysis in a spreadsheet and worked it backwards by starting with wire diameter and calculating the total resistance.  I make the spreadsheet after doing a bar-knapkin analysis and I ended up with the same result.
Using 10 µm diameter copper wire, I calculated the total number of turns in one rank of the coil (using your inner and outer diameters).  Then I calculated the total number of ranks using the length of the coil.  Using number of ranks and your fill-rate factor, I calculated the total length of the wire.  Using resistivity of copper (rho) you gave, I calculated total resistance.
I get 10 meters of wire using 10 µm diameter copper wire yields 2.2kΩ.
Hi all,
Chris thetimeguy was very helpfull in expanding how he measures it and allowed me to share his method here:
"Hi Bert,
The trick to measuring wire diameter is to uncoil a piece of the old
wire, most of a meter is good if you can do it, and measure the
resistance and length.  From that you can easily calculate the
diameter using the resistivity of copper.  You can find online
calculators to do this.  Since the resistance varies with the square
of the diameter this will give you a very good answer, much better
than any optical technique you might try, especially because the
coating thickness on small wire can make up a significant portion of
the apparent diameter.  For thin wire this technique works really
well, and you can easily tell 12 micron wire from 13 micron etc.
I use lots of 15 micron wire and it's nearly an ohm per cm!  Very
easy to measure.
The 1310's wire is much larger than this of course.
There is no reason to believe they stayed the same over the
production of the 1310, so you should measure yours.
Cheers,
Chris
Right now I have done just so and concluded I need 30micon wire for the recoil of my watch.
@chris, thanks again!
Kind regards, bert
He didn't mention, but I've bought every available 0.01 to 0.05mm wire from alibaba, expecting the diameter to not match exactly the description ?. I will double check if the resistance is correct before winding. professional sellers only per x kg's, so ordering a lot to test from alibaba is still much cheaper
strangely the coil short circuited (measured without the rest of the electronics).I did an attempt to unwind/cut a piece (hoping the short would be in that part) and remeasured a few times. At the end not much was left of the coil, so had to take it as a loss.
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
