Greetings, gents.
I'm in the process of replacing a tension-ring crystal on a vintage 1954 Girard Perregaux wristy. I was not aware that it used such a crystal until after I popped it out in a couple of pieces. Bugger was really in there. I tried finessing it out with a standing pliers style GS press but no luck until I bore down a bit harder. I had also tried a crystal clamp but it wasn't able to squeeze the crystal down enough to press it out, even with taps of a nylon hammer head.
Unfortunately the case bezel grew a bit since I first took what I thought was a good measurement of it and ordered that size crystal. And of course the crystal I got is too small. On the next measurement I found out that the bezel grew about .2mm since the first measurement. ?? As I read up on installing tension-ring/armored crystals I discovered that you don't have a lot of tolerance for a crystal that is too large. .1mm is the maximum oversize from bezel that one should use. This, according to the Sternkreuz catalog details. It also seems that I might not be able to use my GS press, nut-cracker/plier style to install it. In addition, I read that it's quite difficult to install them using the nylon dies that come with the inexpensive case presses. Do I have any chance in fitting the right crystal with the nylon dies (Some dies do have the chamfer to fit over the edge of the crystal and reduce its diameter a touch.) or do I have to buy a "real" crystal press that's heavier duty, or at least uses threads for applying the pressure?
The case is a nice 14K case that I don't want to distort. I think I now understand how it is that some watch cases have broken lugs, etc. People probably using the wrong press and/or applying too much pressure. Any suggestions are appreciated. Many thanks. Cheers all.
MrR
There are already a few threads on here discussing this. Mark also made a video. As you say, size is important. Get the size you think you need, and one size bigger. You can rub down the o.d. if necessary. The press you have with the angular contact dies should do the job if the crystal is the right size. The claw tool is the wrong one for this job. You need to get the crystal lined up with the bezel, and the pressure from the die needs to be equal all around.
    • Hello and welcome from Leeds, England . No idea about Citizen but someone will advise soon.
    • Hi Chris and welcome to the forum, The hands and knees is by way of the rite of passage, we have all done that at some time or another.   Added a bit of citizen gen plus the T Z glossary Citizen Technical Information.pdf TZIllustratedGlossary.pdf
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
