I have a Seiko automatic with "Seiko 5" printed on the dial, English and Arabic text on the day wheel, and reference 7009-5330 stamped on the caseback. The crystal is quite "tall" and in good condition except for a significant  7.5mm crack around the circumference of the crystal from approximately the 2 o'clock to 3 o'clock positions. Unfortunately, the way light plays across the crystal makes this crack quite visible and I suspect it is getting larger over time.
I know the reference number is wrong, as images for 7009-5330 do not match this watch case's shape at all.
So, I know this watch's original caseback has been replaced. and I also lack an accurate reference to help me identify a replacement crystal. I also doubt the dial is original, but I like it a lot! I'm actually not too fussed about non-original/matching parts here. In fact, I don't care at all. I just want a new, durable crystal that should fit so I can attempt replacing it.
In these circumstances, how would you proceed? By measurements alone after removing the damaged crystal, or by some other means?
Hi there, welcome to the forum. Youtube have plenty of videos on crystal replacement this link should get you started. You are going to need a crystal press or crystal lift depending on type of crystal you have. More than likely it will have a seal as well that may need to be replaced.
Edited by Graziano
Correct. Having the very exact Seiko P/N is not much important on replacing a crystal, especially on a watch made of assorted, non original parts.
A crystal press is needed as already mentioned. In my experience, unless visibly damaged, the gasket can be left in place.
Thanks for these answers. I have a crystal press en route and intend to order a new one based on measurements once I have it out of the case. A few of my watches are likely to get the same treatment in the coming weeks...
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
