Hi, Could someone kindly post a dial side picture (without the dial) of Orient GMT cal. 40p50 or Orient GMT cal. 40p51 (both with power reserve indicator) ?
I would like to change the date disc and would like to find out
1. The difficulty level for the swap.
2. Compatible date disc for the swap. My current date disc seems to have developed some kind of crack on the tooth (so not moving).
(I am not a watchmaker)
Edited by k3l3k
Surely too high for someone that has never worked on a watch before. You may get into trouble way before you even get close to the part that bothers you, as in removing or refitting hands or dial. Some specific tools are also needed.
Quote
Orient is known to not distribute or care about spare parts. Without measuring the date ring precisely is impossible to even start looking for a replacement.
In any case without inspecting the complete calendar works one can't tell if the date ring is the only defective part, or if it perhaps could be repaired.
47 minutes ago, jdm said:
Thanks for your reply. I am most of watchmakers tools, its just that I am not a professional watchmaker ?, and i have opened and repaired plenty of my own automatics before. It would me my first time with an Orient hence my question.
Edited by k3l3k
Here is a picture of what I requested (from this link) for anyone else who may be looking for it.
Would someone help me with the part-number of the Orient date-disc (the one on mine has a broken tooth)?
Edited by k3l3k
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
