I dug this one out and am trying to figure out how to open it.  Front loader?  I cannot tell.  The front-loaders I have worked on have two-part stems.  This one does not seem to have that.
Any ideas?
This one the back comes off. A very rare and interesting watch movement indeed.Wondering if yours the back unscrews like some vintage pocket watches or just friction fitted if so it will be difficult to remove without the correct tool.
Indeed...that is my dilemma.  I don't want to bung it up.  I will continue to ponder it.  I kinda doubt it would screw on because the battery compartment must align correctly with the movement inside.  My guess is snap on or front loader...does not feel like the latter.
That is a snap back case, you just have to find is there is a pry point albeit virtually invisible, if there is not the patiently and carefully work around the seam with an x-acto knife (a much safer tool that the routinely suggested razor blade) until you have enough purchase to insert a case knife, personally I prefer the Japanese type. In extreme cases, mostly found on current "quality" swiss watches using an hard gasket, then a specific tool may be needed. Check:
Hi Iam inclined to agree with jdm that its a snap back case. I had an IWC that some one blu tacked the battery in as the cover was missing and had to remove the back to remove the gunge.
Have not tried this yet...
Stellaris
The movements below are all marked “Sears, Roebuck and Co.” and therefore the “Stellaris” name is probably owned by this large American Department store. My Westclox and Le Gant watches also carry the same movement but with different retailer’s markings.
The movements in these Stellaris watches are all Seiko 3302A although you’ll be hard pressed to see any identifying markings other than those of the retailer. It runs at 21,600 BPH and is similar to the later Seiko EL-370. Access to theses movements is through the acrylic crystal; the stem is removed by pressing a small tab between the dial and case edge — on the first photo below where the crystal has been removed, you can just make out the gap at the 4 oclock position. There is a battery hatch on the back. All have a crown between 2 and 3! They probably date from about 1973.
Stellaris also used other electric and electronic movements in their watches, such as PUWs and ESA Dynotrons.
Any ideas?
Any thoughts on what this case is made of?  It is soft.  Maybe gold flash...maybe gold plate (doubt it), brass...???
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
