1 hour ago, Lexi178 said:
How to adjust date on curren 198 quartz chronograph watch please any help would be appreciated tanks
Normally with the stem pulled out to the 2nd position.
What is printed on the dial does not mean anything at least in this case. If you can remove the back post a clear picture of that.
Hi  As jdm explained we need to see the movement to be able to identify it and therefore advise you on the procedure. Curran watches are based on Miyota movements of which there are a lot of models fitted to third party watches.
    • Thank you @Mark. I only became a Patreon subscriber 5 or 6 months ago, but I draw so much value here. If you come up with future contribution or support opportunities, I will be on board.
