Hey there,
I would like to work on just another disassembly, albeit patiently, but I seem to have the wrong cheap watch to start with.
From the pictures, it could be seen that the case is milled to exactly the movement diameter. In other words, the movement holder is actually an integral part of the case.
This means I can't remove the movement and the dial as a single piece. Instead, I'll have to remove the mineral crystal first, which will likely make the movement and dial removable in one piece. And even if it is not the case, removing the hands safely is certainly better than attempting to remove the movement from the case back side anyway.
The crystal is definitely mineral, even with an anti scratch coating. The edges are beveled and there's absolutely no way to grip it with the acrylic crystal remover.
If it helps, the crystal is big, at least 37mm in diameter.
What are my options? I have my nuclear option but I don't want to act stupid.
Bonus question : what's the movement? It sort of resembles the ST-16, except that it isn't (but I can be wrong)
Edited by SudoHalt
If indeed the mvtholder is part of the case(of which I am not sure according to the photos) you can gently put a bench knife between the bezel and the case and take the bezel of, normally the crystal should be held in place by the bezel.
The crystal is a normal crystal, not a very big size.
Thanks a lot. Probably the crystal isn't large, but it's the largest watch I ever laid my hands on!
May I ask, since I have never attempted this, how much force should be required? I have previously removed the rotating bezels on Seikos and Vostoks. Should I expect this one to be as easy, or is there considerably more force required?
On the other hand, I am preparing for the scenario where the bezel is too tight. Apart from breaking the crystal, I got another stupid idea... Since I am able to feel the crystal gasket by my nails, do you think it's a reasonable idea to attempt to rupture the crystal gasket by the means of a razor, in order to free the crystal?
As said by watchtime I also agree with his comments and would think that the bezel removes with the crystal intact. Some require a fair degree of force to remove and may need a tool such as the tool attached.  Refrain from trying to work the crystal out as this may lead to damage of the bezel and the crystal seating and ruin the gasket.
No I don't think is a reasonable idea. A caseback press that can also do some crystal work is very cheap. In watchmaking as well other trades the idea is that one tries hard to repair, not break things.
Depends on the wtch/brand. What brand is it? Can you post a photo of the front of the watch. It is supposed to keep water out so it should not be very loose...?
Take a razor blade or a sharp bench knife to get it off, you can put a piece of gaffer tape on the bezel/cae and cut through it. You wan;t get scratches then....I am wondering where you feel the gasket? Not on the front I guess? To be sure, have a replacement gasket ready, When replacing crystals with gaskets, I change these too.
Edited by Watchtime
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
