I'm watching this Cuban chronograph on eBay. I put a 404 on it, but obviously that didn't take. I would be willing to go a fair bit higher for an unusual chronograph though. The listing claims it's totally functional, but looking at the movement, I can't help but feel they're ignoring a non-functional chronograph complication. I think a lever, and possibly a cam are/is missing that would engage the clutch wheel. I see no mechanical linkage between the pushers and that arm. I am also not familiar with this movement, and have never actually worked on a chronograph, so... A wise man knows when he doesn't know, and all that.
Beyond that, see a missing case screw, a slightly mangled jump spring on the minute counter wheel, some screws that have been less than lovingly manipulated, and some very slight corrosion. Typical stuff for the bottom of the barrel, but no deal killers.
I doubt I'm actually going to buy it (truly not very motivated at this point), but being able to diagnose from afar as well as photos will allow is a valuable skill I'm trying to master.
Edited by spectre6000
This looks very much like a Landeron (48, 50 fill in the blank). Seems complete mechanism wise to me. I'm guessing it's a Russian copy of some sort but I have zero knowledge of Russian watches so I'll leave it there. Look at some Landeron 48 images and compare.
It most certain looks like a Landeron 48, almost complete. The minute recorder jumper looks homemade.
The cam on the hammer looks a little worn.
The regulator is in full – position so the hairspring is probably sticking to something.
One screw is missing as you say.
Otherwise it looks complete and running. The case is to an Landeron 148/248 so this is probably an transplant.
Oof yes, minute jumper is homemade and probably 20x too strong for sure. Might jump at full wind but doubt it at 24h. 99% chance a landeron jumper would work,  and they are out there.
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
