Even though I haven’t yet had use for one yet, I've been watching staking sets on eBay. I pulled the PayPal trigger on one yesterday.
Hopefully I made a good choice.
Mine was only $75 but defiantly had some rust and I was never able to clean the stakes up as much as I would have liked. Yours seems pristine.
Well done Don. :)
I just love the description of the die plate! "made of THE TOUGHEST ALLOY STEEL KNOWN TO SCIENCE" .................Brilliant! B)
Thanks guys!
I hope you're right about the Bergeon stakes, Bob. One of my concerns with buying an old set was finding replacements.
Indeed, half the stakes out of true due to them bashing around with each other, and the base from UK to Finland, and when I showed eBay and the seller after a dispute, eBay sided with the seller, go figure.
What the heck!
Ebay always sides with buyer for the tiniest of problems but when someone has a real problem they go the opposite way!!!
Is there not an escalation procedure?
Case was resolved according to eBay as the seller offered to take the items back but I decided to keep as the seller wouldn't cover return shipping cost.
The automated case bot was happy with the outcome.
In the uk it is against consumer law to put a customer in a worse position than he was before the purchase. Ie they HAVE to refund postage.
www.which.co.uk/consumer-rights/regulation/distance-selling-regulations
Looks like a top notch staking set you bagged yourself there, just hope it don't arrive like mine did..
Untitled by Micky.!, on Flickr
Ouch. That sucks. I just emailed the seller, who is supposed to be shipping today, to ask him to package the items securely.
Thanks, SSTEEL.
Except this was probably an auction and so consumer law does not apply.
Looks good. Hope you don,t have the same issue I have with mine. The two smallest holes are blocked and I have never found a way to unblock so I use a stump when needed.
Thanks, Clockboy. You mean the two smallest holes in the anvil are blocked?
After seeing SSTEEL's picture, I emailed the seller and requested that they pack mine securely. Not only did they do that, they marked each row of stakes separately so I could put them back exactly where they were. They also found 20 or 30 "bonus" parts that had been stuck behind the wood things that the stakes fit into and sent them along. Can't say enough good things about this seller.
Bummer. I still haven't used mine yet. Hopefully I don't have the same problem. But I do have another Moseley anvil for backup.
It,s not a real bummer I just use a stump, its just annoying but not a big issue. I noticed that Cousins are now selling a new one for approx £150 and in my opionion it,s well worth a look.
@Don: Nice set Don, and great choice since you will have plenty of new spares when you need them! Congratulations!
@Micky: That was terrible Micky, I hope you sorted it out in the end. Did you have to replace the damaged parts, meaning, was there a way to fix them at all?
Cheers,
Bob
    • If the watch is new, just return it to the seller for a refund or replacement.
    • Keevo, Welcome to the group ! I'm thinking that you have some damage to the hour, and/ or minute wheel. Possibly just a bent, otherwise damaged, or missing tooth.   Your photo didn't post that I can see. I think you'll have to open it to start really finding the issue. Best, Randy
    • An industrial break cleaner , like Holts does a good job of rinsing off paraffin
    • In cap jewels on several watches I have serviced over the years. I've recently serviced a couple of Longines movements where the cap jewels were colourless. They are a real pain. Without colour they disappear when immersed in any liquid for cleaning 😲 Not necessarily. Cousins do a 10ml bottle for £26 which will last me for years. That's just half the price of a simple Bergeon silicone cushion, so not too expensive 🤣
    • I wanted to post an update as I have two movements running really well now, 230-250 amplitude , 0.5 and under beat error, and +/-8 seconds or so. I removed the hairspring assembly in order to start over and noticed that the terminal curve between the stud and regulator arm was distorted. The stud was lower than it should be. I massaged the curve to look pretty good and reinstalled it. I followed Alex's video advice, best I could with 10x magnification, and with the regulator arm set in the middle of the curve I adjusted the stud so the spring was centered. I then made sure I could move the regulator arm the entire terminal curve without upsetting the coils. I then put it back on the Timegrapher and began closing down the regulator pins until I saw a change in amplitude which means to me that the pins were now pinching the spring. I opened them slightly and it looks good except I have a 0 on dial down, +3 on dial up but -16 on crown down.  I'm a bit stuck on how to adjust out the positional error. I also noticed a drop in amplitude, 180-200 on crown down. In the other video link I posted at about minute 26 if I remember he adjusts out positional error by manipulating  the regulator pin gap. With crown down the hairspring falls away from the pin and the rate slows so he closes the pins a bit to keep them tighter in crown down position. That means the spring is tighter on dial up as well but then he moved the regulator arm to slow the movement.  There must be some Seiko experts here that have some methods for dialing out positional errors.
