Hi
 A friend of mine is trying to mend my Landeron 48 chronograph movement.
He has replaced the flyback lever but we are having trouble locating the pushers ..
anyone know the part reference please?
Jon Brook
Yes item 2 is the flyback lever (8180) for the stop/reset action and the operating lever, item 8, (8139) to start the chronograph.
The hammer (8219) is what they manipulate. The hammer spring (8350) is what operate the hammer itself by pushing into the cam slots in it.
Most often when you have a poor action with the pushers the culprit is the fly-back lever spring item 7 (8340). When this isn’t working correctly you will not have a snappy transition to the stop mode. The hammer spring will just stick halfway down on the cam .
When putting the pushers in you will see they have two different lenghts on the pin, one shorter for the flyback lever and one longer for the operating lever.
Edited by HSL
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
