10 minutes ago, Homer said:
How do I stay logged in long enough to complete a message?
Your issue may be browser specific and settings within your browser.  What browser are you using?
Could be security settings in your browser...set this site as a "trusted" site.
I am sure sysadmin will chime in with more specific help...
BTW, I am permanently logged in myself--using Firefox.
Using Safari on a Macbook.  Haven't had any problems on other forums.  It seems to log me out at 10 minutes whether I am typing or just reading posts.  I'm on my 4th log in .
2 hours ago, Homer said:
It's really irritating after one has typed a complete response only to find it disappear when you submit it!
I will try to post from an iPad and see if there is an issue.  My desktop is Windows based.
Try to install Firefox on your Macbook and see if you experience something different
Posting from my iPad. Seems to work well
Most likely a security setting in your browser. Perhaps you have cookies disabled for this site. If I was getting reports from multiple members then I would be concerned that something is wrong with our end. But I’m not and I can’t replicate your issue (I’m on MacBook Pro 16 inch with safari running latest updates and just tried on iphone - all good) so as far as I can see there’s nowt to fix.
benefit of doubt - test with a different browser. Download Chrome or Firefox.
I use either a Ipad or a MacBook Pro neither restricts my time on the site. Does it do the same on other sites
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
