Hi folks,
I need to clean day and date wheels which are painted (or stickered?) brass. Any advice on how best to do this? I don't really want to put them in the ultrasonic. I think a soapy water bath and cleaning back side with brush? Thanks.
Funny you should mention it. I cleaned a Timex date wheel last Friday with warm water/washing up liquid and a cotton bud. It worked on the most part with the dried on oil, and then for the stubborn stuff I used a little lighter fluid gently working it in with the cotton bud. This is all I have to hand and depends on how the date/day numbers are applied, so go careful.
I'm sure there are better methods, and someone will be along to share. I'm no expert. Good luck, post a pick of the before and after.
I would use nothing more than mild soapy water on a cotton bud, dampened not soaked. A lot depends on the composition of the decal, white paint base and transfer printing,  anything  harsher could lead to disaster.
Thanks to you both. Sorry, I should have said, my concern is more with cleaning the underside. The dial sides are both fine. This is a Raketa 2628.
It's funny as in depth as modern tech guides get they never talk about this. Vintage tech sheets you're lucky if they say anything about oiling much less cleaning (some do, both modern and vintage, about what not to clean).
I've always run around the teeth with new Rodico. Pluck off schmutz with same for top and bottom. In 20 years never had an issue. I would never put them in a cleaning machine or use any cleaning products on them, especially vintage,  too big a risk .
    • Hello and welcome from Leeds, England . No idea about Citizen but someone will advise soon.
    • Hi Chris and welcome to the forum, The hands and knees is by way of the rite of passage, we have all done that at some time or another.   Added a bit of citizen gen plus the T Z glossary Citizen Technical Information.pdf TZIllustratedGlossary.pdf
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
