I found a nice NOS case (stamped with '2789 0567 360') for an ETA 2789 movement I have.
Great - just drop it in, and a smart new watch.
Problem is, the movement case ring is too wide to fit the case.  So my question is -
Anyone know a good supplier of movement case rings  - or is it just ebay ?
There are a few on ebay which look suitable - the 2789 is the same diameter as 2824, 36 etc.
The existing ring is quite chunky - I only need to lose 0.6 mm to make it fit. I'm going to see if I can fix it to a drill somehow
and use a file on it  ? (whilst wearing goggles)
Edited by mikepilk
  • mikepilk changed the title to Movement case rings (for ETA) - where do you find them ?
7 minutes ago, watchweasol said:
Give Cousins a look.  I know they do an assortment for retro fitting, whether they do specifics i dont know.
That's always my first search - didn't see anything suitable
26 minutes ago, LittleWatchShop said:
What are the dimensions...ID, OD, height?
Inner dia 25.6 mm, outer 28.5 mm. Height about 2.5 mm
These kinds of things are certainly possible using 3D printing.  I just threw this together as an example.  Can be far more complex lines if needed.  Lots of 3D print shops around that will print your stl file too.  You don't even need to invest in the printer.  Just an idea.
I thought the same, and have been browsing 3D printers on Amazon this afternoon !
I've no experience of 3D printing - but was considering something like this
https://www.amazon.co.uk/gp/product/B08DR3WCV5?pf_rd_r=EAGSGGBV9W97H6V5B3NS&pf_rd_p=6e878984-68d5-4fd2-b7b3-7bc79d9c8b60&pd_rd_r=8d24a0b5-2ebb-484f-8e1d-0c716f116a7f&pd_rd_w=Keueh&pd_rd_wg=wx3l9&ref_=pd_gw_unk
My experience is only with FDM style 3D printing (where you feed a filament into a nozzle and it is melted and added to the whatever is below it.)  SLA printers start with a liquid polymer that is selectively cured as the image is pulled from the liquid.  I hear that SLA printers are more accurate.
I have been 3D printing for about three years and I wonder how I ever lived without it.  Super utilitarian.
The software I use is open source, so there are no costs or licensing issues.
28 minutes ago, mikepilk said:
I'm tempted to get one - I'll do some more research first
I have a Lulzbot Mini.  The 3D community is really high on the Prusa which is sourced from Europe.  If I were to buy one today, I would start my research with the Prusa.  I like my Lulzbot a lot, but it is becoming a bit dated in terms of capability.
I have printed battery inserts for my Wittnauer Electrochron, custom boxes for my electronics, stand to hold a pocket watch, replacement handles for my oilers (my dad would put the broken ones in a drawer and buy new ones), custom threaded bulkhead for my water collection system, on and on.  When I bought it, I had no idea how I would use it other than for custom boxes for my electronics.
https://www.ebay.ca/itm/Vintage-Military-WEST-END-WATCH-CO-PRIMA-Automatic-MOVEMENT-SS-WATCHES-R2/224194467209?hash=item3433081589:g:6ocAAOSw8GFfh1Vf&redirect=mobile
Hi Mike. I hope this link would open on your device, it shows a kind of movement ring integrated with dust cover, I got a dozen of them and would need a day to check OD on them for one that fits in the case you have bought. It would be one made to house eta 2789 .
Joe
Joe
Forgot to mention that my tablet did not open the links in your post, I need to see the case  and  its back plate.
I couldn't get the images loaded yesterday - it's worked now
Hi Mike,  The movement itself is 5.9 mm thick, dust cove would add about 1.5 to that, so you need like 7.4 mm depth inside the case, Not all brands use dust cover. I think I can tell if you case accomodates a dust cover if I see its inside and the back plate.
Hi @Nucejoe. I solved the problem. I pushed the ring on to a felt cone polisher on my electric drill. With the drill clamped to the desk, I used a fine file to take the ring diameter down until it fit. ( I wish I had a lathe)
The only problem then was about a 0.5 mm gap between the dial and the inside of the case. Fortunately I found a thin gold tension ring from a glass which fitted perfectly.
As @LittleWatchShop suggests, a 3D printer would be good for making this sort of part.
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
