I've replaced an old Ebosa 111.861 with an ETA 802.002 in my mothers silver watch, just as a webpage informed me that this model was discontinued and the ETA was its replacement.
It does fit exactly into the watch but the minute hand does not fit. It may be a vague question, but is this normal? Have I picked the wrong ETA model, or should I do something with the minute hand to make it fit? I tried pressing it rather firmly but it didn't work. The hour hand fits exactly.
3291_Ebosa 111.861.pdf 3576_ETA 802.002.pdf
Yes it is normal with replacements. You can either make the hole bigger with a broach, or buy a new set of hands that fit this movement.
Should not press hard to force fit the hand as you may get a bent or broken min arbour.
If you do not have a broach, I use a thin sewing needle to punch the end of the tube open with. till it press fits gently.
The hole is too small - I will try using a sewing needle.
Pity I ordered stuff from cousins only last week, I could have ordered a set of broaches! (the import costs now are relatively astronomic due to brexit...)
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
