This just came in client said watch keeps stoping. This is what I found. date window frame on dial is loose hitting hands and loose movement hold down screw jammed against barrel. My question is I can't seem to find the stem release pin. I'm so used to working on swiss watches ? Help
I'm attaching an image Snipped from yours. There are two places the first light blue circle that's where the  release pin would typically be. Which I'm assuming is not what it is but that's where it would be if it existed.
Then the light pink area nothing is there exactly what the image shows? Except sometimes on Seiko watches and this resembles a Seiko watch the release only becomes visible when the Watch is pulled in to setting.
Some Seiko but which ones? On the current 7S / 4R / 6R and I assume many others the release point comes out with the stem fully pressed in.
Now I read that it is a derivative of the Seiko 7006.  That makes more sense based on the size of the movement.  The rotor does look like the 4206.  I have never messed with a Seiko 7006 so not sure how they compare.
15 hours ago, thewatchdoctor said:
Neither of those even looked at that lever looking thing in the top rhs corner.
My bet is on the lever.  Just ran across a similar system (Seiko) in a front-loader.
Once I removed the movement case ring it became obvious when I pulled out the stem to its furthest position. The hidden lever appeared almost like a puzzle box. The big lever btw is for the quickset day even though there is no pusher for it on the case. This set up is contrary to all my experiences with Swiss watches where you push the lever before pulling the stem. JohnR725 was right.
Edited by thewatchdoctor
A bit more delving and I found out on 17jewels the cal 46493 is a smaller version of the seiko 4206. A more recent version of the same caliber looks like the citizen / miyota 8203.
Pull the crown to the hand setting position, I think that a lever should appear next to the stem to push and remove it.
EDIT: Oh! I see you already found it ?
Edited by aac58
51 minutes ago, thewatchdoctor said:
Next question watch is running and second hand moves but hours and minutes don't. Hours and minutes turn when setting the time ?
This is a classic problem with canon Pinions. If the canon pinion has too much slippage then the hands do not move but they will move when you set the watch. Then because the secondhand is independent of the setting parts that's why it will continue to turn. When you're trying to set the watch does it feel super loose?
Then can we have a picture of the case back I want to look at the numbers found on it?
Cannon wheel was loose. The center wheel end is flush with the jewel looks like it the end has sheared off in the cannon pinion. Must of been a hell off a drop. Would explain the loose screw and the date window frame. I know the owner does enduro / motocross which might explain it. Now to search through my broken seikos to see is anything fits I know Ive some seiko 5 seven series.
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
