Hi, I own a new Casio Waveceptor Atomic/solar WVA-M640, which I bought on E-Bay. It is the one with the "rubber" band. I like it a lot. I did notice that the crystal is on so that it is slightly thicker at the 12-o'clock position (I mean where the crystal meats the case) than at the 6-o'clock position. I don't know if this is intentional by Casio, or just a minor issue of the crystal being manufactured that way, or if when the crystal was put on the case they didn't quite align it right. Any ideas? I would be grateful. It is a very minor issue, but I am just curious. It doesn't affect my use of enjoyment of the watch at all. Thanks!
I just had a look at mine which was bought new on Amazon a couple of years back.  It's the same way.  Slight enough that I'd never have noticed if you hadn't asked, but definitely projects less at 6 than it does at 12.
    • Hello and welcome from Leeds, England.  Photos please.
    • This is the old/first(?) way for making a mainspring for an automatic. "Evolution-wise" it is an logical first step forward from a standard spring. Usually these are indeed replaced with a new spring with an integrated/fixed bridle. Lubrication as you would do with any automatic.
    • Thank you. I was informed it was a cheap worthless Lack watch from India. It’s in a small mens watch looks to be around 1930 odd   Cleaned the movement and it’s going really well. Keeps good time.  This is a great site. Mystery solved. I’m obliged.
    • I'm working on a Schild AS 1250 (a 'bumper' automatic) and it's the first time I've seen a mainspring like this. It has what looks like a regular manual-wind mainspring with a 'hook' at its outer extremity. On a manual-wind watch that 'hook' would engage with a 'hook' in the barrel wall to prevent it from rotating. However, the AS 1250's mainspring does not engage directly with the barrel but rather with a 'sliding bridle' that sits between the mainspring and the barrel wall, and evidently facilitates the slip necessary in an automatic. I'm not sure what advantage this two-piece configuration provides, but it highlights a gap (one of many) in my horological knowledge. I'm not sure if 'hook' is the correct term as used above, but please see photo below to see what I mean. Therefore, two questions please. 1. What is the proper way to lubricate a barrel from an automatic watch with a sliding bridle? My guess is the same as any automatic ms/barrel (e.g, a few dabs of braking grease on the interior barrel wall). What do the experts say? 2. I purchased a Generale Ressorts GR3472X mainspring, made for the AS 1250. It looks like the bridle is included and I don't need to salvage and re-use the old one. Is this a safe assumption? Thanks for the advice. If you have any other wisdom you'd like to share about separate sliding mainspring bridles, I would be very interested. Cheers!
