Hello
I would like to learn to polish watch cases and bring them back to life. Would something like Dremel 3000 do the job? I guess the number of RPM is important to be able to do the final polish properly. I prefer to do everything I can by hand and the last part to finish with a rotational tool.
Thanks.
I do use a drummel tool for stainless steel watch cases as it will remove all scratches. I have some YouTube videos on this from years ago.  Use red paste and rpm around 15, which I assume is 1500rpm. Do not do this with anything but stainless steel and mask all other areas of the watch. Done this many many times.
You can do righteous work with one of those tools. I prefer a bench polishing lathe (I can hold the piece with two hands and use larger buffing wheels), but I find I use a handheld tool often, too. Clamping the piece in a bench vise helps avoid slips and increase control.
    • Hello and welcome from Leeds, England . No idea about Citizen but someone will advise soon.
    • Hi Chris and welcome to the forum, The hands and knees is by way of the rite of passage, we have all done that at some time or another.   Added a bit of citizen gen plus the T Z glossary Citizen Technical Information.pdf TZIllustratedGlossary.pdf
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
