Hello
I have two questions.
1.) I'm restoring a brass plated dial with newly lumed numbers. Do I protect the dial by spraying on a clear or mat varnish from Humbrol Paints? I don't have an air sprayer so I would either apply the varnish via a brush or an aerosol can. What do you recommend?
2.) Does newly applied lume cure to a hardness that can be sanded down? I may have a few areas where the lume is built up and won't allow the hands to pass. Instead of removing the lumed area and reapplying it, I'm wondering if I can simply sand down the high spots?
Thanks in advance for any advice that can be given.
Michael
Hi there , sanding down the lume would make marks that may not be visible to the naked eye but would be clearly visible under magnification .Why not strive for perfection and redo the lume,after all this is what watchmaking is all about and practice makes perfect ,then you will learn the properties of applying lume.Not only that but you risk damaging other parts of the dial .If at first you don't succeed, then try again as the saying goes.Take your time and strive for perfection.After all your are doing a restoration .
hope this helps ,Graziano
Oh and I forgot to mention sanding the lume will remove the fine natural film on the surface leaving rough surface allowing mould and other types of defects to occur more quickly
Edited by Graziano
Hello
Thanks for the suggestions. I've never worked with lume before and so I don't know the properties of it nor what I can and can't to it. This watch and it's dial will be a rewarding learning experience.
Michael
1 hour ago, mcoulton said:
Hello
Michael
Hi there Micheal, here's a link to a video, that should help you understand luming
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
