Hi, I am trying to restore a Seiko 5M62-0D50 Kinetic. The crystal needed replacing and the face needed aligned as someone (me) had assembled it off by about 5degrees having replaced the capacitor. I don't know if I lost something last time but there seems to be nothing to locate the face relative to the movement. ie it spins freely and once in place, cannot be accessed to correct it. Can anyone give me any pointers?
The dial feet must have broken off. You will need to remove the dial and either
  • attach new ones - I've superglued them on, or they can be soldered (tricky)
  • use double sided sticky tabs to secure the dial (not great)
  • look for a new dial
Can you remove the dial and post a pic of the back of the dial and movement ?
Welcome to the forum JR.
Mark has done a YouTube video on your very watch with the same problem, well worth watching.
There are other videos dealing with this problem but watch Marks first you'll find it worth while.
Good luck.
Graham
Yes I agree with the other comments, The dial feet have broken off. New ones can be soldered on  or glued on although with the glue on ones you have to be careful of the calendar work for clearance. I built my own tool for the job and never had a dial spoiled.  Common fault on Seiko's
Mine is the LH one  the RH one is a Horotec .
Not sure that I can remove the hands. I'm almost in over my head already. If I pluck up enough courage, I'll post a pic. Thank you for your advice. I would never have guessed dial feet.
Graham thanks very much for the advice. I don't yet know Mark but Google is my friend.
Thank you for this. I was beating myself up for losing a gasket or something. That's a pretty advanced piece of kit that you built. My tools so far don't go much further than decent screwdrivers and a starter kit off ebay:(
Thank you lads. I would never have solved this riddle on my own. I honestly believed that I had lost something years ago, when I done the capacitor job. That's when the dial went wonky and I have been beating myself up all week because of that. I'd be back on the drink had I not have found this forum. I have replaced the crystal as the old one actually had a hole punched in it. I never felt the impact at the time but I guess that's when the dial feet went walkies:)
Yeah, I see the problem. Been looking at the solutions and I defo can't do a professional job. I wouldn't touch this with the tools I own. Gonna go for the tape I'm afraid.
Hi, here is another YouTube video you might find useful, this dial had been glued on with contact adhesive.....nasty ?
Not nasty when recesses are cut first. This tecnique is demonstrated in comparison to soldering by our Host Mark Lovick.
Hi JDM, was referring to how the watch had been stuck down before the renovation, fabric and contact adhesive.
Watch was repaired using metal feet and adhesive ?
    • The ones I have opened also do not have a pry point , hence the reason for the tool. The watch is clamped in the tool and a blade is screwed into the seam, the blade being chamfered lifts the back then the screw shaft is turned and the back comes off have a look on Ali express for case back removal tools
    • I don't think I need to know more about the Orient watch question, so please don't write anything related to the topic, but if you know where I can buy the watch's jewels = rubies and gems shock protection, I would like to know.
    • It's an exhibition back so no access as you suggest.
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
