I recently purchased a vintage Certina sporting a stem that wouldn't stay put. I worked on it a bit, but either I can't get the stem secured or I get it secured and can't switch between setting positions.
I'm wonder if a part is missing. I was unable to find any technical document for this movement, but I understand it's similar to ETA 9360/1/2 and found a parts list for that series. Regardless, I was unable to identify any missing part(s).
If anyone has experience with these movements and can help, I'll post pics.
Best regards,
Doug
AS/ETA/ESA 536.121 are the same. Schematic diagram may exist, otherwise, you should take picture as you disassemble to the keyless, show us a picture of it please.
Regs
Joe
Photos:
  1. All the parts laid out minus the setting lever jumper screw. Anything missing?
  2. Double corrector operating lever, sliding pinion and stem installed
  3. Setting lever installed
  4. Yoke installed
  5. Setting lever jumper installed and screwed down
I'm able to move the stem back and forth between two positions. Ignoring the fact there should be three positions, the two positions don't feel right--very difficult to move between.
Is the stem correct for this movement?
Help appreciated.
Thank you,
Doug
Thank you, John!
I checked the document: except for the missing savoir faire, everything needed is present.
Thanks again,
Doug
Is there another pin/protrusion under the set-lever? If there is, it would seem that the set-lever should be rocking lower on the stem to engage with it. Good luck.
From the photos, it looks like the position of the sliding pinion, yoke and setting lever are not sitting correctly. The sliding pinion should be a little further back and the yoke should be in the groove of the sliding pinion. There should be a pin on the underside of the setting lever which should be in the groove of the winding stem to prevent the stem from being pulled out.
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
    • The case back is perfectly aligned to the case and has no provisions for a screwing tool. The T-Sport series has snap on backs.
    • For me the text looks too aligned and with no obvious way to grip as a screw back.
    • There’s no indents & there’s no little groove to pry it off anywhere! So I don’t know if it’s screw down or pry off 👍
