Tissot 2581 Technical Document/Communication?
I don't think I need to know more about the question now, so please don't write anything related to the topic. Thank you to everyone who wrote. Have a nice day.
The case back is perfectly aligned to the case and has no provisions for a screwing tool. The T-Sport series has snap on backs.
