Hi, Does anyone have any advice for a stubborn case back that just will not snap back into place? I'm using a case back press but all that is happening is the bottom die is flexing. Its the right case back, the gasket is good and correct.( the one that came off), It is aligned properly but it just will not seat.?
I'm about to resort to my shop 20 ton press.☠️
10 hours ago, ShawntheBrewer said:
flexing.
Always nice to give us pictures.
shop 20 ton press.
Did you notice if you are assortment of dyes for your case press is proper they come in a variety of shapes and sizes? Some case backs need to be pressed on the edges otherwise if you try to push in the middle they will never go on. Even with a 20 ton press if you're pressing in the middle the outside edges flex out and they will never grab. But the watch might look quite interesting if you flatten it with a 20 ton press. Other watches do require pressing in the middle so you have to press in the right place not necessarily with lots of force to get the backs to go on.
I stack 3 quarters on top of each other on a counter top and place the watch face up on them and press down with palm of my hand. Its always worked,so far.
Thank you for this. It never occurred to me to press on the outside edges. ?
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
    • The case back is perfectly aligned to the case and has no provisions for a screwing tool. The T-Sport series has snap on backs.
    • For me the text looks too aligned and with no obvious way to grip as a screw back.
    • There’s no indents & there’s no little groove to pry it off anywhere! So I don’t know if it’s screw down or pry off 👍
