I bought a citizen Eco Drive watch nighthawk fb3002 53p as a project watch. It's a beautiful watch but not working properly . The watch's chronological functions are working but the hour/minute/second hand are not working . It's a very strange problem, but that also means that the battery is fine. Has anyone else faced such an issue , any help is welcome. Worst case , where can I find the replacement movement ?
Thanks in advance
Hello Rishah and welcome to the forum.  If the chrono functions are ok it could be the time side coil or a jam in the gear train.  Could you open the watch and post some pictures of the movement. That way members will be able to identify the movement and point you in the right direction      Thanks
Does these help, I am assuming not, I lost my thinnest screwdriver to open the 3 screws, if I find it will try to get inside
Could you post a picture of the rear of the movement and the caliber / make of the movement . As it may be cheaper to replace the movement as a whole if they are available.     Thanks.
Hi  quite pricey.   If toy have a line release or demagnetiser you could remove the capacitor and try inducing a magnetic field which makes the hands move rapidly it might just be a case of a jammed or sticky gear train  do it in short bursts not prolonged.
    • The ones I have opened also do not have a pry point , hence the reason for the tool. The watch is clamped in the tool and a blade is screwed into the seam, the blade being chamfered lifts the back then the screw shaft is turned and the back comes off have a look on Ali express for case back removal tools
    • I don't think I need to know more about the question now, so please don't write anything related to the topic. Thank you to everyone who wrote. Have a nice day.
    • It's an exhibition back so no access as you suggest.
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
