The main spring is snapped! ?
Not sure how to go about finding a replacement, is by length? Any idea how to measure the length of the coil?
The inside diameter of the barrel is 16.9mm, the spring is 2.5mm wide and 0.2mm thick.
Obviously, being a fusee it has no return like modern springs, its just a straight coil with a hole on either end.
48 minutes ago, oldhippy said:
You measure the diameter of the barrel and it's inside height.
Can’t Find one on Cousins, any other good sources for replacement springs?
The specs are:
Barrel outside diameter - 18.3mm
Barrel inside diameter - 16.9mm
Barrel outside height - 3.8mm
Spring Width - 2.5mm
Spring Thickness - 0.2mm
Spring Length - 410mm
Have a look at the Resources at the top of the page. As it’s very old you might have to get the nearest to your measurements. You could try ebay.
Cousins has it. Search mainspring by size, 2.50 height 0.20 thickness and you will get everything that matches that. There's one for a 17mm diameter barrel which is perfect for you, 50 in stock.
Thank you.
I decided to strip the fusee before looking for a spring and may have met disaster.... after opening the fusee it looks as though one of the tiny clicks has broken off its tip. I can’t imagine this will be easilly replaced!
Found a job lot of fusee’s on ebay for £15. Took a punt, fingers crossed I can either steal a click from one or simply replace the whole fusee if one matches. ??
There are a few bad teeth on that wheel, that is due to the spring breaking. Lucky the chain didn't snap. You might be lucky with ebay.
    • The ones I have opened also do not have a pry point , hence the reason for the tool. The watch is clamped in the tool and a blade is screwed into the seam, the blade being chamfered lifts the back then the screw shaft is turned and the back comes off have a look on Ali express for case back removal tools
    • I don't think I need to know more about the question now, so please don't write anything related to the topic. Thank you to everyone who wrote. Have a nice day.
    • It's an exhibition back so no access as you suggest.
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
