Hi all,
I am working on a cute Pobeda for my significant other. It was running great, but after taking the balance on and off a few times, the hairspring stud has come loose. The pin just appears to have backed out of its hole - the hairspring is vertical but the stud is flopping around all over the place.
My basic plan is to, under a microscope, hold the stud upright, and push the pin back in using hairspring tweezers or an oiler. Any advice about tools or methods? Seems straightforward but obviously there is much that can go wrong here. Pivots are good and I already reshaped the overcoil, so I'd rather not junk this balance. Thanks.
Normally this is done with a studding table, which is a tool that clamps the stud at whatever height you want so you can clamp it with the hole sticking out at table height. Slide the spring in, then insert pin.
Most folks don't have that tool, so the next best thing is the cock itself. Fix the stud in place, insert spring, then pin. To press the pin tight it's very useful to modify a pair of tweezers by removing about 0.25mm from the end of one side; now you can rest against one side of the stud with the short end and squeeze the pin in with the other side.
Hi Nicklesilver   any chance of a picture of the studding table sounds quite an ingenious device.  I have always used the cock as is and threaded the spring when pinning (days long gone now)
Thanks guys for your resposes. @Nucejoe, the movement is a Zim 2602 with a fixed stud. Here are some pictures of the balance and stud itself. As you can see, the stud hasn't come off - it's just flopping around all over the place. I can flip the stud to lean the other direction and take the same picture. Do you guys advise removing the pin and starting from scratch, or just trying to push the pin back in? And yes, I know the pin looks super weird and rough here.
Edited by JohnC
Hi JohnC,
Doesn't look it would creat any noticable beat error, which is a pain to adjust with fixed stud holders.
In case you feel no master re-pin ner, I refit the stud with the cock, put em back on the mainplate and just use a bit of epoxy 5 to keep the hairspring in place.
Good luck.
    • The ones I have opened also do not have a pry point , hence the reason for the tool. The watch is clamped in the tool and a blade is screwed into the seam, the blade being chamfered lifts the back then the screw shaft is turned and the back comes off have a look on Ali express for case back removal tools
    • I don't think I need to know more about the Orient watch question, so please don't write anything related to the topic, but if you know where I can buy the watch's jewels = rubies and gems shock protection, I would like to know.
    • It's an exhibition back so no access as you suggest.
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
