Should be access to the click in the hole under the last P in Philippe. You have to disengage to click in the auto system as well. On that note, on this caliber, if the click in the auto gets out of adjustment even a tiny bit (there's a fine wire spring that acts on the auto click) the automatic will either not work or will wear itself out in a matter of weeks. A friend who worked in Patek strongly recommends against messing with this caliber unless you have access to parts or aren't too concerned if the watch no longer works, hahaha. He said he had calls every week from service centers asking how in the world to set it up correctly.
I also got a weird hairspring that are not magnetize and keep sticking to each other , I tried One Dip and Lighter fluid still not working ?
That's odd. This would have a Nivarox hairspring which while still somewhat magnetic should be impervious as far as timekeeping and also coils sticking. Sounds like you have something on there, try clean acetone. I'm guessing you don't have a magnetism detector! And hopefully this is your own watch?
4 hours ago, Oyster said:
can't find the proper way to unwind the mainspring, thanks for the answer !
That is a very high quality and expensive watch movement. Without access to parts or a tech/ service sheet personally I would not attempt. I am just not that brave
I second that. It takes very little to irrimediably damage an hairspring that to all effects is unreplaceable. The safest approach is to only let a reputable watchmaker touch this piece.
Sorry to say if you don't know how to let it down I don't think you should undertake such a task. I will tell you but if anything goes wrong it will cost you a great sum of money. Patek Philippe service charge is about £500
You remove the auto then let the mainspring down as our friend nickelsilver said from the hole next to the last P.
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
    • The case back is perfectly aligned to the case and has no provisions for a screwing tool. The T-Sport series has snap on backs.
    • For me the text looks too aligned and with no obvious way to grip as a screw back.
    • There’s no indents & there’s no little groove to pry it off anywhere! So I don’t know if it’s screw down or pry off 👍
