Hey guys! I recently acquired a 1971 caravelle diver with a plastic resin, one piece case. Entry to the movement is through the front. I removed the bezel and crystal thinking that I could just remove the hands and maybe the dial would come off exposing the keyless works. However, when I lifted the dial I was able to catch a glimpse of the edge of the movement and I could clearly see a dial foot screw. It it possible that I have a two piece stem? Does it just pull out with some force? I don't want to break anything, but would like to clean and service this watch as it's been sitting for who know's how long! Any help would be appreciated. The movement looks to be a hand wound bulova 7089. I checked ranftt but didn't see any info. Have you guys seen this before?
Before exerting brute force, try turning the stem around a little at a time just in case it is two piece with a slog that will allow the movement to drop out when you find the correct position.
If that doesn't work, then brute force is more than likely required to remove it. I have not worked on one of before and these are just my thoughts. I hope someone can give you a definite answer.
I have never worked on this movement before but from the picture on the right, I can see a small "space" between the dial and the case @ 3 oclock. I wonder if it is some sort of ring that holds the whole movement in the case or simply a small gap to get to the setting lever somehow...
Thanks for the responses guys! I saw that in the pic too, but it's just a reflection of some sort. No space there on the actual watch. Geo, I thought about that and attempted to free it that way yesterday, with no such luck. I read somewhere that someone used a cannon pinion puller to pull it out as it allowed them to use the least force necessary to do the job. Maybe, I will just look at it a bit longer first. It's keeping great time, but I want to clean and oil it!
That was me taking the stem out of my Tissot.
Nice watch .Looks like a Tissot Sideral . Have one of those . My stem can be pulled out with some force . Doesn't have a split stem .
Didnt Mark show this in a video. The one he used compressed air to pop off crystal to get to movement?
I think that was a Omega dynamic
I have seen someone use a plastic bag and a plastic syringe . The plastic part of a syringe not needle . Placing the bag over the pendent tube and then the syringe over the pendent tube . Press some air in and pop .
  • Similar Content
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
