Hello folks,
I've just completed a restoration of a pocket watch, but it's some no-name brand, with no logos/names on dial or movement. Since I'm fairly new to this, I was wondering if anyone could help me with learning a little more about this type of movement. It seems like a late 1800's watch, key wound and key set. What sets it apart from any other that I have so far worked on is that this particular movement does not utilize a pallet fork.  Instead, the impulse jewel directly engages the escape wheel. I have never seen such a movement and a google search does not help.
Would it be correct to assume that the lack of pallet fork utilization causes the timegrapher to go insane and return no results with dots all over the place like looking at the night sky?
Thank in advance!
What you describe sounds like it's a cylinder movement. If you Google cylinder movement you will get loads of information about the design and history of these calibres.
To identify your particular watch it would really help if you posted some photos, good clear close ups will give us something to work with.
Hello and welcome to the forum,   If you could supply some pictures of the movement front and back  then members will have something to go on and maybe then able to help you.Without su ch information it is just guess work.   Thanks
Thanks for the answers! I can take some photos, but the movement has been re-assembled now. Perhaps a macro lens can show the assembly with a better view. I'll give it a shot.
That's definitely the one! Thank you! Your help is much appreciated.
So can these be adjusted by use of a timegrapher?
One more question. What kind of lubricant would you guys recommend for this escapement? It deals with a lot of friction. Would 9010 suffice?
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
    • The case back is perfectly aligned to the case and has no provisions for a screwing tool. The T-Sport series has snap on backs.
    • For me the text looks too aligned and with no obvious way to grip as a screw back.
    • There’s no indents & there’s no little groove to pry it off anywhere! So I don’t know if it’s screw down or pry off 👍
