Hermle 400 day clock
HectorLooi
Ok, I think I got it now. I'll have to put in some sheltered spot to see if it will keep going. The glass dome was missing and I think some draft must have upset the oscillation.
An anniversary clock is a great way to learn escapement theory. Everything moves so slowly that you can see every step. Drop, lock, full lock, power, unlock.
Unscrewing that won't make any difference to the going of the clock, those holes are not elongated. If you didn't have the movement covered then draft could have caused it to stop. Try and put the clock out of the way, away from everything.
The holes on this Hermle are definitely elongated. I don't understand why as the pallet has actual adjustable pallets. My Kundo anniversary clock had round holes.
But working on this clock has really deepened my understanding of escapements.
1 hour ago, oldhippy said:
I can't recall seeing that before. How stupid is that.  Whatever you do do not adjust the pallet faces. I don't suppose you marked the plate when you removed the first screw.
Thanks. I'll remember that. I wasn't expecting an elongated hole. It was only when I was putting it back together that I saw it. ?
How would you mark the plate? Would you use a scriber?
  • 10 months later...
I've got one of these clocks and am having the exact same problem. You have some very good pictures and I see that your pallets span five scape wheel teeth. I cant get mine to span more than four for some reason. I'm told the long number is the movement number and mine is the same. Moving the bridge frame is the normal way to do the last final adjustment. More common on clocks with non-adjustable pallets.
I've made parts for and renovated a good many 400 day clocks and this one is on the point of having me beaten! I've checked everything and can't find the spot between fluttering and jamming. I used to think Koma Midgets were the worst....
Has yours got the proper top block on the suspension spring? ie with a semi-circular cut out? If you have "The Book"I think its 25b
In order to know how many teeth between the pallets you need to work out the teeth count to the pinions. Have you checked for wear on the escape wheel and wear on the pallets. Have you got the pallets in the right position. How much space between the pallet forks and pallet bar,  a tiny drop of oil between the two stops fluttering.
I can't recall. I've since sold off the clock so I can't check it.
But I think everything was original with this clock. I didn't change anything except the suspension wire and getting a new glass dome.
I did manage to get pretty good amplitude from this clock after playing around with the pallet depth and getting it in beat.
With your vast experience with 400 day clocks, I'm sure you'll figure it out.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
