Hello!
The title pretty much explains it all. The setting lever spring for my Eterna 520u has snapped and I need a new. I've been looking for a few hours and I have had no luck! Can anyone direct me on the right path? Thanks. :)
Kind regards
Mathias
This site https://calibercorner.com/eterna-caliber-520u/ indicates that the 520U is the same as the base 520 with the U just indicating use of an in-house shock (I only mention this because, unusually, ranfft doesn't list the various 520 models together with family/generations information and instead lists them separately).
With that in mind you don't have to be searching around 520U exclusively; the base 520 should use the same setting lever spring. A quick look on ebay and I can see two sellers with the item.
