This is an ongoing project for me. I have just replaced the hands and dial on this watch, as well as servicing and replacing some damaged internal parts.
When I got the watch, it had a very poorly fitted crystal that dropped out with very little pressure from the inside.
I have installed a generic crystal that is nice and snug so it is working for now. But I would love to find the right NOS crystal for it. Ebay has many listings for crystals, with the diameter listed, and usually Omega part numbers form the paper envelope, but I am currently lacking the research knowledge to figure out what the correct part number would be.
I know I need a 29.6mm crystal with a silver ("white") tension ring, or at least I am reasonable sure that is correct.
I have found images of the parts breakdown for the movement parts but nothin similar for the case.
Can anyone point me to a good reference for the case parts?
IMG_4553.thumb.jpeg.83b7d60849fff62b42c4f1af4c39a6f7.jpegIMG_4538.thumb.jpeg.06954273d20467b79f0bf4ef1d242f9f.jpeg
Cousins says part number PX5000. But that’s a gold ring type, oddly. I’d try fitting a Sternkreuz ATC which should be a very close match. Size = rebate diameter + 0.1 or 0.2mm.
If you go to cousins battery on the case number in the document search you'll get the PDF I have attached
Based on the PDF your number is more or less correct you just have to change one of letters. Then it looks like there's a seller on eBay  not cheap of Although cheaper than what Omega would sell it to you for
63PZ5000  GLASS PLEXI ST RING D29.62 H4.3
https://www.ebay.com/itm/NOS-Vintage-Omega-watch-crystal-PZ-5000-for-Geneve-ST-135-012-042-Genuine-100/274690748194
7377_Omega 2576 CK Case.pdf
