Hi, I’ve just come to this lovely hobby and am a bit stuck finding any info on the date wheel assembly.
When I removed the plate holding the wheel, I photographed the loose prices lying underneath. Some were still in place, so I can guess they are correct. There is one spring that was sitting there. Would I be correct in thinking it goes in the recess like the other spring that is still in place? If it does, is there a correct way to point it? Thanks in advance.
Hi Bob  what is the caliber number and make of the movement, with that we may be able to find you some information.  As a rule the spring pushes the detent inti the date wheel so that when it steps over it checks it into position, when assembling the front plate and fitting the springs either use rodico to hold the spring or do it inside a large clear plastic bag, that way if parts go flying which they are prone to do you will have them captured in the bag. Saves hours on the knees with a magnet.
Thanks for that great advice, this is a basis pin pallet, sacrificed for a learning experience. It’s a non runner 582 Bf seams to be the info under the balance.
When I was working as a computer engineer and contacted support for anything it was the first thing they said (have you read the manual) So i got into the habit doing that first, without it can be guess work and not following procedures and lead to danger or broken machines.
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
    • The case back is perfectly aligned to the case and has no provisions for a screwing tool. The T-Sport series has snap on backs.
    • For me the text looks too aligned and with no obvious way to grip as a screw back.
    • There’s no indents & there’s no little groove to pry it off anywhere! So I don’t know if it’s screw down or pry off 👍
