Hi
After a lot of work (because I'm a beginner) I've lost the spring of an incablock(it was in my tweezers then he disappear literally).
I've managed to get another one from another movement. the same one
First question: can I use another spring to replace the existing one
Second question: how to replace this piece it seems impossible to me because it jump all the time you try to touch it
I join the model of the incablock spring
Thanks for your help
Shape the end of the pegwood so it fits just inside the setting, next hollow out the middle of the end of the pegwood so that there is space for the dome part of the jewel and spring. Apply pressure and twist.
Good luck.
Anilv
Looks a kif trio, not incab, there is a special tool for this
Remove and put the bridge on a hard surface to gain more control over the task (important).
     The wooden tool anvil speaks of is a good idea. many approaches have been discussed before.
I slide two prongs in the groove , hold the spring down under my thumb nail ( you have more control with your fingers as compared to tools)  turn the spring with tweezers (move each prong a little at a time) to get the third prong in the groove.  Rinse and dry.
4 minutes ago, Nucejoe said:
kif trio,
Like so many things in watch repair there is a tool. I have a picture of them so you can see what they look like. Three prongs to correspond your spring. With the tool it allows you to get all three prongs underneath where there supposed to be when you rotate. You can get them without the tools it is just more fun.
http://www.ofrei.com/page745.html
https://www.cousinsuk.com/product/kif-shock-springs
https://www.hswalsh.com/product/kif®-shock-spring-tools-watch-set-3-hs1310
Hello
Thanks for the help read a lot about these spring KIF. I'm going to try first with the pegwood tools as described by anilv.
If I do not succeed I'll buy these special tools.
They are not too expensive but I don't know how much use I'll have for them after this movement.
In any case my advise keep them preciously as the piece price is 3.95 pound + shipping  (not bad for 0.1g of metal).
Best Regards
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
    • The case back is perfectly aligned to the case and has no provisions for a screwing tool. The T-Sport series has snap on backs.
    • For me the text looks too aligned and with no obvious way to grip as a screw back.
    • There’s no indents & there’s no little groove to pry it off anywhere! So I don’t know if it’s screw down or pry off 👍
