I've been messing around with a Pulsar led module 5408-2 last few hours.  the display will light up and was fully functional but after a few hours it starts to not respond.  What I had done originally was to blast it with some electronic cleaner than held it near a heat source.  That got it to work but now again the display is acting up.  Cold solder somewhere?
A cold solder joint is definitely a possibility.  More likely a probability since you have shown that it is working in real time.  Could also be contacts to the battery...but I imagine you have already explored that.
If batteries were left in it and they deteriorated, the acids (or whatever) from the battery could destroy circuit traces...but that seems unlikely given that you have made it work in real time.
What does the pcb look like in the pulsar?
I'll take out the module tomorrow and add some pics. right now I'm calling it quits for the night. But I did lookup the original price of this watch in 1976  and it sold for $395.  That would be  $1,853.82 in 2021.  back in 1976 I was working part time and making  $2.50 an hour pumping gas.  Guess either way I would have to wait 45 before I could have one....
I remember my dad getting one in his shop for reasons that escape me.  I wore it for a day and felt very important!!  I have several Longines LED watches that are not working.  Have not explored the cause for their failure.
well it ran well overnight but the time display button is a bit odd. It takes a few presses to get the display to light up. Than it goes whacky such as the AM and PM segments stay on.  If I take the batteries out than a random digit lights up.  I guess this is why it went into the sock draw of the original owner.160895531_362146458251652_4135234947405717580_n.thumb.jpg.8d86d22c4056443b2f6fb29c004dc61f.jpg160757889_294055352081807_6931358648408012155_n.thumb.jpg.8b1829fb2547488e1f66e4e204a8a47d.jpg160898089_944990699642193_4994983109036705255_n.thumb.jpg.a10a8bb81df486f2eefe63ca43315620.jpg
Well...you could try to touch up each exposed solder joint.  It's a crap shoot.  Do you have the equipment to do that?  If not, you could send it to me and I would give it a shot.
I believe the contacts of the display switch have oxidized and are not closing the circuit properly. If the switch is replaced, I believe the circuit would work just fine.
There's at least two replacement module makers for the pulsars, they use the original LEDs  (and quartz crystals?) but modern batteries and circuit design, so I would imagine they would have better battery life. I haven't tried either, but they look interesting. At least one of them has the option of adding a few extra functions, like the month and date display with a long keypress.
https://pulsarledtime.com/Replacement-LED-Watch-Modules/
http://www.strikesandspares.eu/modpulsar.htm
    • The ones I have opened also do not have a pry point , hence the reason for the tool. The watch is clamped in the tool and a blade is screwed into the seam, the blade being chamfered lifts the back then the screw shaft is turned and the back comes off have a look on Ali express for case back removal tools
    • I don't think I need to know more about the Orient watch question, so please don't write anything related to the topic, but if you know where I can buy the watch's jewels = rubies and gems shock protection, I would like to know.
    • It's an exhibition back so no access as you suggest.
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
