Hi all,
I figure these movements were kind of popular and expensive (they are still available). So, since I just saved US$104, the price of them this side of the pond (take or leave a few dollars) I wanted to share my experiences.
First off, the service data:
233_Seiko5M42A,5M43A.pdf
Now for the disassembly:
My order here is a little odd. The movement was in bad shape being an ebay non working watch, just for the exercise at hand. Therefore, sometimes in order not to damage a part, i.e. circuit or coil mainly, other parts are being taken out of the way first to facilitate the disassembly. In some pictures, there is another similar movement which also was used to eventually put together a working one between the 2.
So, here is the 5M42, notice that the 5M43 only adds the day disc, a selector gear we'll mention later and a disc holding clip. Everything else is the same. The new capacitor kit that replaced the bugged original one is: 30235MZ which is also good for the following movements:5M62 and 5M63.
post-253-0-85781500-1428281213_thumb.jpg  post-253-0-64776100-1428281215_thumb.jpg
There is no capacitor present in this movement...
Notice that this movement can be disassembled each side without interfering with the other side. This means that we can remove all the parts from one side and then turn it and remove all the parts from the other side. Your choice which side you want to start first. I prefer to remove the rotor and keep going on that side (bottom) to ensure there is no damage to the rotor screw and bearings. As an added advantage, I'm also minding the coils and circuit.
I would have removed the capacitor clamp, insulator and capacitor unit. This is only possible after the previous step and before the one being illustrated below.
Removing the circuit block cover:
I also removed the oscillator weight (rotor) bridge first since the circuit seemed kind of stuck and wanted more visual/elbow room to tackle it:
A closer view of this bridge, notice the intermediate wheel for generating rotor:
Now we have a full view of the electronics, in very delicate estate I may add. Luckily the circuit block is OK ( I used the one from the other movement which was in better shape ):
Then, goes the short coil...and the long coil, the generating rotor and generating stator:
post-253-0-14471000-1428281319_thumb.jpg post-253-0-00756400-1428281322_thumb.jpg
post-253-0-24790600-1428281324_thumb.jpg  post-253-0-68152400-1428281325_thumb.jpg
We remove the only screw holding the train wheel bridge and look under the "hood":
post-253-0-03453800-1428281328_thumb.jpg post-253-0-94830700-1428281329_thumb.jpg
Here is the underside of the train bridge. You are seeing the setting wheel still stuck to the bridge:
In the following pictures we remove the fifth wheel and pinion, fourth wheel and pinion, third wheel and pinion, step rotor, minute wheel, center wheel and pinion...
post-253-0-24524500-1428281333_thumb.jpg post-253-0-60828600-1428281334_thumb.jpg
post-253-0-11620600-1428281376_thumb.jpg post-253-0-81724300-1428281377_thumb.jpg
post-253-0-36988400-1428281379_thumb.jpg post-253-0-83454200-1428281380_thumb.jpg
Then we proceed to the keyless work et al. Removing the train wheel setting lever, switch lever (careful is under tension), setting lever, capacitor connection and yoke:
post-253-0-63786300-1428281382_thumb.jpg post-253-0-09850600-1428281384_thumb.jpg
post-253-0-83605100-1428281385_thumb.jpg post-253-0-19124200-1428281387_thumb.jpg
We discover underneath the clutch wheel and remove it. Also the rotor stator is removed:
post-253-0-69766600-1428281461_thumb.jpg  post-253-0-29324900-1428281463_thumb.jpg
At this point we turn over the movement...or what is left of it:
As you see this one is the 5M42 version without the day disc feature. Normally for the 5M43 we pry, carefully with a small screwdriver, the snap for day star for dial disk, the day star with dial disc and the intermediate wheel for day correction. All those parts are similar in shape and location as to the 7S26 mechanical movement so there is no need to illustrate it at this point...if we had gotten it. Note that this movement uses a dial washer.
So we skip the day star and start removing the date dial guard and date dial:
Underneath is the familiar date jumper reminiscent of the Seiko mechanical movements, date driving wheel, intermediate wheel for calendar correction, date correction setting wheel, and hour wheel. I'm not sure about the plate present in this movement, it might have been one of those franken things, but this plate doesn't have the non-removable antimagnetic shield plate. I used the donor movement main plate since it had it.
Here is a picture of the movement using the antimagnetic plate:
So removing each mentioned part:
And voila! The bare plate:
Now we only need to remove the holding ring for dial and dunk everything in the cleaner...NOT everything! The generating rotors, both coils and circuit block DON'T go in the cleaner! Nor would go the capacitor if we had one in this case. Everything else is fair game. One note of caution, while assembling use plenty of rodico for each part since magnetism is an issue and can attract undesirable particles into the movement. Always check and recheck!
From this point on and after cleaning the parts. Assembly is simply a reverse order. Follow the technical data for lubrication...I simply used moebius quartz oil and simplified everything...and maybe a little Seiko S6 here and there, mainly keyless works.
One important data for those who don't have a multimeter and want to check the coils. You are measuring 2 different ranges of resistance/impedance, if your meter is not autoranging, make sure to change the range accordingly.
Here is the final product in its case and with temporary hands...until I get something I really like and can refinish the case.
I also forgot to say that this movement uses hands: 65/110/20...so far difficult to find in sport, luminic types...or so it seems from trawling the net!
Hope all this helps! Enjoy!
Cheers,
Bob
PS. Any insight, corrections, suggestions, etc is most appreciated!
That's correct icius, I believe that's the name for the same movement by Pulsar, a Seiko division. Thank you for the nice words!
By the way I'm editing the above to add something I forgot!
Cheers,
Bob
And this is why kinetic service prices usually aren't cheap.
Watch looks nice as it is, but I wouldn't mind seeing it refurbished with your final choice of hands.
Very interesting, thanks for the post, bob.
Edited by Ishima
I echo Ishima's words Bob!
Very informative, and thanks for taking the considerable time to photograph and document the journey. :)
  • 8 months later...
Hi Bob,I wonder could you help me please, my watch was working OK but thought it was about time after 10 years to give it a service
Seiko wanted about £100 to give it a service
I am not very well versed in watch repair but thought after seeing your guide I should be able to do it
I removed the train wheel bridge but cannot get it back on the wheels just wont line up, spent 2 days on it but not getting any where
Took watch to a watch repairer but now I have taken it apart they wont touch it
could you possibly give me any hints on how to get the bridge back on
I don't want to as I am attached to the watch, but if I cant get it back together, will put it on ebay for spares repair
Many thanks Nigel (UK)
What  a great job you have done Bob :)  . Lots of small parts in that movement! Interesting movement with rotor and electronic parts. It's like a mix between an automatic and a quartz?
@nigel: All I can say Nigel is don't despair and have lots of patience. Make sure the wheels are perfectly aligned on the bottom plate before you attempt the upper bridge, be gentle and test often. Tiny parts and small pivots...still quite resilient for the size but not bullet proof so they can be broken and rendered useless...so care and patience is the recipe!
@rogart: That's correct rogart, the mechanical section of the movement resembles in principle an auto movement, with weight and all that turns a tiny motor which in turn charges the capacitor. It all boils down to provide electricity to the quartz that makes this type of watch very precise. I particularly like this version better than the "sun powered" types (from either Seiko or Citizen) since as long as there is movement you have power. One thing that makes this movement, like all electronic/quartz movements, a "problem" is the coils that can be easily damaged. I wonder why then don't encase them or protect them better...one slip of the screwdriver or tweezers and bye, bye coil!....or buy, buy coil :)
Thank you and I'm glad this walkthrough has been found useful!
Cheers,
Bob
Hi all,
attachicon.gif233_Seiko5M42A,5M43A.pdf
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0214.JPG http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0215.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0216.JPG http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0217.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0218.JPG http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0219.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0220.JPG http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0221.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0222.JPG http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0223.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0224.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0225.JPG http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0226.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0227.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0228.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0229.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0230.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0239.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0231.JPG http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0232.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0233.JPG http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0234.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0235.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0238.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif 20150405_224417.jpg http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif 20150405_224439.jpg
Cheers,
Bob
great job. Amazing how standard the Seiko parts are across types
    • Did you just swear at me matey?? I’m sorry, I’m not divulging personal information but there’s always personal reasons. There’s not much more than I can do other than plod along as best I can. However, my health is good now and I’m regularly getting plenty of exercise to keep it that way 👍 You know what. The ads don’t even cover a small percentage of what it costs to serve this site. I find most of it personally. If there are complaints then so be it. I do my best.  in fact - I have zero issues turning them off. Would that make the complainers happy?
    • Same question that was asked last time Hakan, and emphasis was placed on it. It was ignored. The thread should still be there, if not I have a copy of his reply.
    • This is probably the single most important point. One of my best friends, 48 years old at the time, suffered a massive stroke about 15 years ago. He barely survived, but his life was never the same after that. If you had asked me back then to guess which of my friends might have a stroke and nearly die, he would have been the very last one I'd have picked. He was perfectly healthy, played tennis three times a week, ran a successful business, was full of life, and had a wonderful wife and well-behaved teenage kids. The harsh truth is, we never know when it’s "game over." @Mark, I truly wish you a long, happy, and successful life. But have you given any thought to some kind of backup plan for WRT in case the worst should happen? Is there anyone who could keep the site going? If you can reassure us in some way, it would mean more than a lot to us!
    • Update: The demagnetization only helped temporarily, maybe it pulled the wheels into a position where they liked each other. I have to adjust the sub second hand as it is a bit angled upwards and catching the minute hand stopping the whole movement but before this happened there were some wild deviations. HWGIKE#58 Alarm clock, cooked in hot cleaning fluid and oiled gently. This is a movement so I count it. 🙂 A while ago it tried to fly away one day, it was on my windows sill, we had strong wind the curtain flew like a flag and doing so encouraged my clock to do the same...  went out and ended up on the roof above the entrance door, its door in pieces but the clock itself suffered no damage otherwise. The original glass was already broken when I received it I still have the bottom part in two pieces. The new "glass" is acrylic. It also had a paper in the back in the case inside but it disintegrated, I still have a little bit of  piece of that too.     HWGIKE#59 Durowe 870 / Times M84 This particular instance is a D870, when I saw its worn out contact pin I thought that it must be a design flaw, and here we go: https://17jewels.info/movements/d/durowe/durowe-870/ An incredible movement again where the balance wheel drives the train and has two magnets one for the balance wheel/coil and one for the pallet. The magnet for the pallet is basically the "draw" one direction. The coil is about 1.8kOhm and one end is in contact with the main plate and the other end is soldered to a contact pin which is insulated by the means of putting it into a jewel and this contact pin is rubbing against a wire getting the energy/impulse as it is passing. Behind the contact pin there is an "impulse jewel" not sure why is it there... the wire seems to hit the impulse jewel first then the contact pin but maybe it is there only for insulation purposes? I was almost certain that the screw holding down the battery - (minus) clamp had no insulation washer.. i only noticed the green stuff around it coming from battery leakage... anyway the + and - had a shortcut which took me a while to realize.. had to fabricate one insulating washer on my own. The jewel settings were dirty but not it is all cleaned and oiled. The contact pin might work for a while but I am sure it has a short life. It is a front loader the whole thing is held together by the case so it is not possible to regulate it without putting it all together and taking the movement out of the case again, very inconvenient. A wonderful movement but not made for eternity only for the consumer market.
