Another idiot.
oldhippy
Many were fitted with strike works. Here is a extremely good rear with it's original movement.  The early ones were fitted with the verge escapement, many have been converted to the Anchor type.  If you look carefully you can see if it has been converted by the old screw holes that have been left, in some the holes have been filled in. Also converted from chain to rope, the holes the chains pass through get worn over time and are not that round as with rope they stay round.
https://www.periodoakantiques.co.uk/antique-clocks/a-rare-17th-century-brass-lantern-clock-by-jonas-barber-ratcliffecross-london-circa-1690-32-stockno-1200/
On 4/21/2021 at 2:44 AM, HectorLooi said:
https://www.ebay.co.uk/itm/124685278921
Have a look and tell me what you think of this clock.
So many things don't look right with it.  I wonder if this is a cheap "facsimile" of a lantern clock.  The way it's put together, and the primitive way the parts look, it doesn't seem as old as it should be either.  But, admittedly, I don't know a whole lot about lantern clocks.
One of the things that bothered me was the shipping cost? Small clock made out of a lot of brass seems like the shipping cost should've been higher. Although that nifty light weight quartz movement does cancel out to make a lot lighter but still seems like the shipping costs should be higher.
I swear I am way more careful, gentle and try to copy everything I see from professionals. This person may have years of experience yet extremely rough on everything :(. I don’t understand if he’s lucky or truly experienced and knows what he’s doing but in the end he fixes somehow. Maybe it’s me thinking wrong but until now, I saw all the true pros were very careful with customer’s stuff. It hurt me when he hammered the cuckoo clock’s whistle.
It's a complete waste of money. Anyone who knows about clocks wouldn't touch it with a barge pole.
I came across another controversial video. Here we see a clock movement (fully assembled), being dunked into an ultrasonic cleaner.
I was trained by dental instrument manufacturers to never submerge a fully assembled, or even partially assembled equipment into an ultrasonic cleaner. The ultrasonic vibrations would cause parts to vibrate against one another and cause surface wear. This is especially true for ball bearings. The tiny balls would vibrate so violently until they make depressions in the bearing raceways. After that, the mirror smooth raceways would have giant potholes  in them. And if you've ever heard what a damaged dentist's drill sounds like (a banshee), you'll learn never to put a drill into the ultrasound.
So what fo you think about putting a fully assembled clock into the ultrasound?
  • Sad 1
11 hours ago, oldhippy said:
Antique clock movements should never be cleaned by ultrasonic.
I agree. I learnt that the hard way. Recently I cleaned some clock parts in an ultrasonic cleaner using a home brewed ammoniated cleaner. It brightened the brass very nicely but some spots had a matte finish. I think the ultrasonic created some cavitation damage in the brass.
40 minutes ago, HectorLooi said:
ammoniated cleaner.
ammonia-based cleaning fluids in horology do a really nice job of brightening up watch plates for instance. but usually for the watch cleaning fluids just a few minutes in the cleaner will do the job anything longer and you start to dissolve the brass. So a little is okay and too long or too much or too strong is very very bad.
Then if you Google cleaning of brass with ammonia aided cleaners you'll find the general view is it's very bad. They can cause all kinds of corrosion problems stress fractures in in general it's considered a very bad thing to do..
Polishing clock plates you should use Brasso and thoroughly wash in petrol, dry in sawdust and polish with French chalk. I have had this discussion many times, some members say brasso is an abrasive, my answer to that it is not, there are a lot more polish agents that do harm than brasso, it comes in a liquid form. You can also use it with the finest wire wool which I think is 0000 gauge or a soft polishing brush.
Modern clocks such as the westminster chimes and such movements I used Horolene clock cleaner. Use in a well ventilated place as it takes your breath away as it has ammonia in it.
I'm extremely nervous of ever cleaning even the parts of an antique pocket watch movement in one of these.  For this reason, I do not yet own an ultrasonic, and have put off getting one.  I think it would be just fine for cleaning modern watch movements, as the parts would seem more robust, less worn and fatigued, with better metallurgy.  But I cannot yet bring myself to contemplate sticking any antique parts into one.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
