Hello! I'm not sure what it's called when the wheels aren't held in by a bridge but pressure fit on the outside of the plates (see photos). So I guess my first question is what is this type of wheel referred to as, and also what is the best tool to safely remove them?  Thank you!
Dr ranfft reffers to this as " independently driven minute wheel".
Following the tear down, I put the train bridge ( with this wheel attached) back on the mainplate, give it four cleans in ultrasonic and call it cleaned.
I do not remove this wheel unless there is a need to replace a faulty part.
what kinda side shake on the driver arbour do you feel?
Do you have a staking set?
If you happen to bend the driver arbour the slightest, you have created a problem of depthing between the driver and seconds wheel, so if you have not yet mastered fitting the wheel on arbour with your staking set, I think twice .....
I have seen driver wheels get loose off the arbour specially in cases that driver wheel has previously  been removed/ replaced couple times, even peening the center hole on the driver wheel doesn't gurantee much.
In my neck of the woods, the wheel usually gets replaced with a new one on high end watches.
So if side shake on the arbour isn't alerting and all else checks out alright, why bother or creat a problem for yourself, you can always go back if your TG said something is wrong.
I usually inspect the hole arbour goes in, under good magnification for signs of previous removals.
Regs
Joe
Ok I will first try cleaning without removing from the bridge. Thank you! I actually have a staking set coming in the mail next week!
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
    • The case back is perfectly aligned to the case and has no provisions for a screwing tool. The T-Sport series has snap on backs.
    • For me the text looks too aligned and with no obvious way to grip as a screw back.
    • There’s no indents & there’s no little groove to pry it off anywhere! So I don’t know if it’s screw down or pry off 👍
