Hello Ladies and Gents,
I've had this Citizen for over 6 years and it really needs some love. Ive been lucky enough to find another used one just like it so I now have spare links, case and internals if ever needed. However,  I cannot seem to locate the red bezel and I'm not sure where what to do about the crystal. Currently it is a mineral glass with some heavy scratching. Id like to replace it with a sapphire crystal maybe with a blue or red AR coating.
The model info is below. How can I locate the bezel and sapphire? Also is it just a better idea to send it for servicing to CITIZEN repair shop ? Thank you!!!
Citizen - Eco Drive Divers Perpetual Chronograph Alarm - BL5290-59F E812-S043646 red bezel
Hello, the best web sites that I have found to search watch parts like bezels (ceramic, steel and titanium) and sapphire cristal are Aliexpress and Ebay (you just must find same diameters and thickness in the case of sapphire glass) of course they only have compatible parts, not OEM parts.
But you cristal may be restored by using cerium oxide and patience.
Edited by RaulCG
Thank you for this. Is there anyway to figure out the dimensions from a blueprint or something? Or should I buy a digital ruler thing? Maybe I can take apart the spare I have just purchased.
Usually if you'd like it restored to looking like new sending it back to the factory or one other authorized service people is the preferred choice. That's because they should have access to all of the original components providing the watch isn't too old. It may be if you have someone authorized in your area you can ask them nicely and no giving the part numbers for the crystal and whatever else you need and then you can try to put them in yourself.
Blueprints yes the blueprints they exist but were never going to see them. They don't give us blueprints if were lucky we get a service bulletin or something. Like your movement I've attached the service manual. But that's it no detailed blueprints they probably don't want people remanufacturing their watch and were supposed to be just repairing them not modifying them anyway.
Sometimes on some of the watch parts there will be numbers and you can figure out like diameter of gaskets are crystals perhaps it just depends on the watch company.
1443_CitizenE810,E811,E812.pdf
I just did it with an analog caliber or a transparent ruler (cheap option for newbies), of course the best option is a digital caliber to get real dimensions.
Thank you for this!
Thank you for this! @JohnR725 The pdf is a huge help.
    • The ones I have opened also do not have a pry point , hence the reason for the tool. The watch is clamped in the tool and a blade is screwed into the seam, the blade being chamfered lifts the back then the screw shaft is turned and the back comes off have a look on Ali express for case back removal tools
    • I don't think I need to know more about the question now, so please don't write anything related to the topic. Thank you to everyone who wrote. Have a nice day.
    • It's an exhibition back so no access as you suggest.
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
