Hi Folks
I am 74 years old and took up working on watches when I retired in 2009. In my opinion, after getting deeper into the world of watches I understand how much of a rookie to the game I really am! I am going to start out as a listener first to get a feel for things on this forum. But, if anyone would take the time to say hi and answer one question that has been bothering me for sometime now I would be most grateful. When I was regulating a cheap watch with Chinese movement, I found that every time I moved the regulating arm that the beat error would change. Should that happen? I know that when I adjust the beat error the timing is affected. I didn't think it worked both ways. Have I been wrong all this time? If your laughing at this please refer to the word "rookie" above...
Thanks
Learning
I find your title interesting as not all parts of Oregon are known for rain.
Your question is relatively easy to answer providing I make assumptions. Always nice if you would post a picture of your watch and maybe a make and model number. This is because there is way too many variations and my answer will not fit for all watches.
On older watches this wouldn't happen typically. The stud would be held fixed to the balance bridge. The regulator pins would be controlled by the regulator arm directly and the beat would not change. But modern watches to allow more adjustment or basically easier to regulate at the factory everything can be movable. To understand this am attaching an image as you can see the regulator arm is on top of the regulator pins on top of the stud. There held in place by friction move one and conceivably they will all move. This is where you really should have a timing machine if you're going to move anything just to make sure everything is going in the direction you think it should.
Welcome to the forum.
How big of a change are we talking?
You may see slight change in beat error with fixed stud holders too,  imperfections in terminal curve can push the coil to the side therefor the impulse pin out of beat,  as you move the regulator arm.
Hello and welcome to the forum ,  I think JohnR's diagrams sum it all up succinctly, There are two types one with a fixed stud and one with a movable stud. The fixed stud type, the beat should not be affected when the regulator is moved other than as Joe suggests its bearing on the spring.  The loose stud type can move when moving the regulator and therefore will affect the beat,  There fore the need for a timegrapher or equivalent when regulating watches is useful tool to have.
    • I came up with a topic that might be helpful for partners, friends, or family members of watch enthusiasts: gift ideas for people who are passionate about watches. Of course, more watches are always appreciated, but what are some other gift options related to this hobby or collection? What related gifts would you love to receive?
    • Thanks to everyone for the welcome.  Can I ask for some advice?  I have a French Drum clock which I am hoping to dismantle, clean and mend a bit for a friend (it is a long time since I did this, but I would like to restart). I used to go to M & P for supplies but it seems they are out of action at the moment.  Is Cousins a good place for supplies?  I think I will need: 1. Some small watchmaker type screwdrivers 2. Cleaning fluid to put in a bath and agitate the parts in (I don't have an ultrasonic bath and was not proposing to get one) 3. Clock oil 4. Some thin nosed pliers for removing pins 5. A basic magnifying eyeglass 6. A pivot locating tool 7. An assembly support for the movement 8. Some assorted pins .. but probably nothing more than that for the moment.  I don't think I will need to rebush any holes although I do have the tools for this.  The hour wheel is broken but I hope I have sourced a replacement. Final queries:  a. the wooden case has split a bit.  To glue it together, would standard strong PVA glue e.g. Evostik interior wood glue be OK?  b. to polish the exterior brasswork of the face and rear, is Duraglit OK, and should they be lacquered after polishing?  I am not proposing to polish and lacquer the movement itself, unless that is vital, but only to clean it in the cleaning fluid. Thanks in advance and I hope this is clear.
    • Thanks Mark. I think I’ll leave the beat error for now - it’s a fixed stud so I’d have to adjust the collet position.    The watch has bigger problems. On reassembly I’ve found that the hour counter reset hammer is broken - I didn’t do it, the main hammer part was just not there. Can’t easily identify a replacement part. And the subdial hands. The running seconds hand needs an extended pivot tube as the pivot is below dial level. Can’t find one of them either. I’ve found a central seconds hand that might fit it - going to have a go at cutting, filing and polishing it to make it work.
    • Good morning. I have a Caliber 11DO 17 Jewel that I utterly destroyed practicing on. My question is this. Are the 17j and 7j compatible in relation to swapping out parts such as the Wheel Train and Balance? Thank you in advance.
    • Ah ok thanks , i see thing differently now. Won't that catch the wheel rim though ?
