Site not displaying properly
Any pointers appreciated, it’s on my work laptop so I’m thinking it’s something the admin monkeys have done. The forum worked perfectly not long ago but now this, see picture. And it’s only this forum that it’s happening to.
im on google chrome and windows 7 if that helps
I think that IT departments have the ability to stop webpages downloading the graphics portion of webpages. I have had the above happen on my home iMac, but reloading the page generally fixes it. Different circumstance obviously, but I have had it happen.
As far as I know, when you get this, all the links work correctly, you just don't get the graphics portion. Do you get the same thing happening if you now click on one of the links on the page?
I’ll give you a heads up this evening with pictures of what I see, basically it’s like the picture before but with huge full screen single letters between each subject, I can’t click on a link to see the contents of each subject
Have you tried the above said clearing of cache and cookies, as well another browser?
No nothing uninstalled, the works laptop is pretty strict on all things like that, I can’t even have my own desk top background installed anymore as they stopped that with everyone.
I have been informed that there is a new google Update coming soon, so I’ll wait for that to be patched in and see what happens then.
If you are indeed allowed to use your work laptop to view the forum, I would suggest that for some reason your IT department has flagged the page that you are accessing that does not display correctly. Subsequent pages display correctly as their address differs from the address of the incorrectly displayed page.
Might be the result of some automatic security software.
Ring your favourite IT guy at work. Best of luck.
That is technically impossible. WRT (just like any other serious website of the world)  uses HTTPS with which all the content exchanged, including which page is being accessed, is encrypted end to end. The clear text HTTP protocol is disabled. That means that anyone that is even able to intercept the communication, (lke an IT dept) can know that one is accessing it, can block it or even redirect the access, but cannot see or modify what is being transmitted in ether direction.
I’m open to all suggestions so keep them coming please. I’m going through all settings etc trying to accept cookies etc amongst other odds and sods to try and make it work in the laptop.
Im still waiting for the update to filter through and when it does that might make a difference but I’m not holding my breath to be honest
Well I popped into work today to compare settings of laptop to desktop whilst on google chrome, so I set my laptop up next to a desk top logged on and headed to the forum.
Well here’s a surprise, both the laptop and the desktop displayed the forum incorrectly!!
So now I’m stumped, something must be wrong with the internet settings on every desktop/laptop that are on the works system.
 Easy isn’t it, to be fair I don’t actually spend a lot of time browsing as I’m more out the office than in, but a little down time Is nice.
But it’s strange how it’s just this site that doesn’t display, even had the google chrome update done yesterday and still no difference
    • I have been recently servicing an Omega 3220A chronograph movement which uses a Dubois Depraz 2000 chrono module.  This has been quite a time consuming project, not necessarily difficult but with lots of steps.  Working on the chrono module is like working on the love child of a hugely complex keyless works and a Timex pin pallet movement. I do have access to a couple of Omega tech sheets and a couple of relevant Youtube videos (including Mark Lovick's Breitling series) so I feel confident that I have all of the required information. The 'tractor' movement (effectively an ETA 2892) had no issues with obtaining 300 degree amplitude dial up / dial down and maybe a spread of 7 seconds across all of the positions.  I serviced the chrono module and when reinstalling it, this brought the amplitude down to about 260 degress with the chrono stopped and 200 with it running.  The Omega specification states that the chrono running should see the amplitude drop by no more than 40 degrees (from, I am guessing, the assembled amplitude i.e. chrono stopped rather than just the bare tractor movement). Obviously this isn't good enough. I am going to have to redo the chrono module again.  Where I suspect I have a problem is inconsistent / over oiling of pivots.  For some reason the Omega technical guide states to apply oil to the bottom pivot of each wheel and then place in the jeweled base plate.  In practice, I managed to smear oil on the horizontal base of the wheel which would be smeared over the outside face of the jewel.  This also wouldn't be helped by dragging the wheel around trying to get the lower pivots to engage in the the jewel.  When I watch Mark service a similar Breitling chrono with DD module, he also oils the bottom pivots and installs the wheels (obviously doing a better job than me!).  My question is, why can't I install the wheels dry and the oil the jewel on the other side of the base plate in the conventional way? The top pivots are oiled through the jewels in the conventional way, so why would the lower pivots be any different? Looking at the those jewels (picture below an example from a different movement) it looks like there isn't an oil well in the outside surface of the jewel around the pivot, so perhaps I would be better applying a drop of oil directly to the jewel hole before installing the wheel?  Perhaps the jewels have different arrangement to conventional jewels because the outside face is installed against the dial side of the tractor movement and we don't want to risk oil migrating from the module to the movement. There are also a couple of friction springs that may have an impact on amplitude, I will recheck their pre-load but these should be OK.  Is there anything else I should look at as a source of friction in the DD module?
    • I found a Trupoise in a flea market box of tools (🇬🇧car boot). I preferred the ‘8’ style tool until the moment I broke my new Omega rivet. The trupoise holds the arms firmly and I’ve become quite efficient… …and I just resorted to bending a balance cock. I needed a tiny bit less shake and it seemed the least risky of the other options. I held it between a stump and a fat stake while I bent the jewel end with my fingers. Honestly I don’t know how anyone would know by visual inspection.
    • It was about 4 years ago, one was 30, another 35 and 2 others came in joblots that I was after something else. 3 have ruby jewels and one has ceramic bearings.The most I've seen one sell for is £330.  In the uk i still see them sell occasionally for around £70.  I'm not convinced that the Trupoise has low enough friction on the pivots to be as good as a traditional tripod poising tool with unworn ruby jaws.
    • I have a Record 525 which is in a pretty bad way. From what I can see it is based on a cal 650 with an automatic bridge and centre seconds pinion under the rotor retaining stud.  There are additional bearings in the train bridge for the bottom pivots of the automatic works. Of these, on has come out of the bridge completely, one is a bit mangled with an egg shaped pivot hole and one is half in, half out. I've made bearings from scratch on the lathe before, but only for pocket watch pivots (i.e. considerably bigger than these!) and these bearings are either plated or not brass, to match the bride plate, I would guess. I could not find a bridge on eBay so I started digging. I checked new Ranfft site (not help, but the new one seldom is) then the cousins download centre but I could not find a document for a cal 525. I did, however find one for the 650 and, scribbled on the page are the words "= Longines 701". So, obvious next step (or so I thought) would be to check the docs for Longines cal 701 and then see if there is maybe a cal close by, based on that cal with a rotor. I checked, no 701 in the downloads section.  I did find some Longines 701 parts on eBay, which look similar to the 650 (i.e. the train bridge looks to be the same) but I feel I have hit a dead end. I have added some pictures that you may find helpful and I have photographed the entire strip down so I have more, if needed.  I feel I have few options: 1. Close the brewing holes up and reinsert the loose bearings. Close up the pivot hole on the 3rd bearing and hope that does the trick. 2. Make some new bearings (doable but tricky and will look wrong) 3. hold out for a 525 bridge to come up online. I get the feeling this is a rare movement though (all the more a shame it is in such a bad condition) 5. See if there is a Longines equivalent and either use that, or transplant the bearings from that bridge to the Record. Any help identifying the Longines equivalent (if it exists) would be appreciated. Any suggestions on the alternatives I have discussed are also welcome
    • Really you paid that little for a legit Trupoise?
