Anyone Have Experience Using Vissin Fluid?
Ishima
This is just a point of curiosity really, I have no immediate plans to use Vissin.
But it's a very interesting thing, and I'm wondering just what it's application truly is. Cousins says to heat the fluid and submerge the item, but I've heard of people applying drops of it to the thread/screw? And at any rate, how would you know when it was safe to use without corroding the item you wish to extract the screw from? I've read the .pdf upload of the little manual-pamphlet but it's little help, mostly just health/safety and environmental/disposal information.
Hi Ishima!
I had never heard of Vissin Fluid before seeing your post so I Googled it just to see what it was. I'm not much wiser now than I was before (no real surprise there) other than knowing what it is supposed to do, but I bet there's a chemist on here who will tell us more.
The fluid must be pretty corrosive if it dissolves steel screws but how it leaves the surrounding metal unaffected would be interesting to know. Perhaps it's designed only to react with ferrous metal. We shall perhaps find out! :-)
Woah, that's incredible, I bought some Alum Immediately after seeing that! (might take a few days to show up)
Any idea why the steel crowns are okay, but the stems get corroded? are stems made with a different chemical composition than crowns?
Also make sure the metals are different as above since I've ruined crowns made of steel...not stainless steel. Other chemical I've experimented with apart from Alum which has to be warm to work, is chlorine but it is really aggressive and the crown need to be other than steel and even non plated. All in all, my rate of success is roughly 50/50 so far.
Cheers,
Bob
Oh right, of course, I didn't even consider that.
I'm right in saying that most steel crowns are infact stainless, though?
Will this react with other materials, such as enamel or cabochons that can be sometimes found on the top of crowns? and the micro gaskets?
Edited by Ishima
I don't think there will be many crowns made from steel, hopefully Bob can tell you what ones to avoid. As for your second question, I don't know, you would have to put that to the test yourself. If anyone does know the answer please let us know.
Can the alum (or vissin, maybe) remove by corrosion, the staf from a balance weel? I heard that there is some kinf of acid (don't know witch one) that can do this job, dissolving completely the staf with no afect the blalnce wheel. Better than punch out the broken staf.
Edited by RicardoG
It probably would Ricardo, but I would rather go the traditional route. If it was a split bi-metallic temperature compensating balance of the type fitted to quality pocket watches, it would dissolve the steel and completely wreck it.
Good point Geo, looking from this angle you are correct. In the other hand, the balances that have this bi-metallic temperature compensating are made with an aloy of metals and not a surface coat, that can react with acid and be removed (if I'm not wrong).
I appreciate the vote of confidence but honestly I'm more into trial and error here! When I have enough crowns, I deep them in alum and heat. I'm using an old coffee maker to keep it warm. Then I brace for the surprise! ...meaning some will come out OK and some won't! Since they are -- so far -- for my own hobby (not customer's) I don't give it too much thought. I usually replace those crowns with new ones on the watches I service and if I can recover the old ones, then it is a bonus! One thing it is not advised is to use this method for diver, screw on crowns since the alum will cut through and spoit the whole spring/housing setting.
Anyway, I have to go now I'll post more if I can think of anything els.
Cheers,
Bob
Might be that i bought the one bag of alum on the market that has a slightly off ratio/mix of chemicals, or i just didn't mix the right ratio of water to alum, or maybe not and maybe it doesn't require that much thought. I have two items in the little jar of mixture, hopefully one will be effected.
  • 6 years later...
13 minutes ago, Colditz said:
According to the data sheet it is sulfuric acid so pretty corrosive. I would also like to know how this stuff works so does anyone else know if it is good for screw removal etc.?
I have used it quite a bit in the past*. It is exactly for dissolving screws stuck in non-ferrous parts, and works really well. The normal procedure is to pour some in a ceramic dish on a little stand, and heat it with the part in it over an alcohol flame. The heat seems to be pretty key. A normal screw just takes a few minutes to dissolve or at least dissolve enough to drop out.
*I usually machine out broken screws nowadays.
Edited by nickelsilver
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
