Hello dear watchmakers.
I am about to work on a vintage Omega constellation automatic watch.
However I am having trouble getting the movement out of the case.
Movement + dial is stuck and won't come out from the back so I tried opening up the glass and that didn't work out very well.
Would it be necessary to open up the glass or is there a correct way ?
Thank you.
Remove the Bezel complete with glass and it should come out from the front use a loupe and find the edge of the bezel there is usually a slightly larger gap somewhere along the outer edge usually opposite side to the winding crown so you can  use a blade to remove it.
